Headlight Shopping List
Apologies if this has been answered now but I can only find guides relating to the Sewell package. If I were to buy Headlights 2011-2012 for my 2007, what and all do I need to make sure I have? I have AFS lights so I heard I need to turn that off first or I will have a light warning. Beyond that, what should my shopping list be?
Much appreciated and if this turns out well I'd be glad to list all of the options in this post for future reference.(If one is not created already)
IS '11-'13 MY Headlight Parts/Numbers
Flasher[1x]: 81980-06020
Headlight Caps(Round)[2x]: 9007566004
LED Wires w/ cap[2x]: 8112553540
Mounting Bracket(Optional - Can modify old one)[1x each]: ??
Diagram:
http://is.sewellparts.com/images/oem...000/815445.jpg
Instructions:
Loaded(Sewell):
https://www.clublexus.com/forums/is-...on-how-to.html
Stripped: Regular 2011-2013 Headlights with no parts other than the lights
https://www.clublexus.com/forums/is-...tallation.html
Ballast Dissasemble(Part of Stripped only - or if you bought new headlights(11-13) that didn't contain ballast):
Diagram:
Instructions:
Loaded(Sewell):
Well that's partially what I'm curious about. As I would rather find some used lights than pay full price for new ones. If its relatively easy anyway. I don't so much mind the look of 07, but mine are starting to turn yellow for some reason very frequently. I clean, then they are good for a month or 2, then i have to scrub them down again. Really annoying. Plus I kind of like the look of the '12.
I used this guide: https://www.clublexus.com/forums/is-...tallation.html
But I didn't do it as thoroughly as he did - I just did the plug and play method. If you're electronically minded you can easily make a relay so that it works like OEM but that was a bit out of my skill set :c
