Difference between locking carrier assembly and welded diff?
Old 12-04-13, 03:39 PM
2012IS250
2012IS250's Avatar
Default Difference between locking carrier assembly and welded diff?
I am planning on purchasing a locking carrier assembly but I was told that it's no different than a welded differential. Is this true? If it is, are there more cons than just additional tire wear? This car is my DD and I'm still going to be driving this car for another year and a half to two years until I get another one and I don't want anything to break because of the locking carrier assembly. If anyone knows anything about this, please give some advice. Thanks!
Old 12-04-13, 03:59 PM
mike33
mike33's Avatar
locking differentials are for off road use... When turning on pavement the wheels need to be able to rotate at different revolutions, a locked differential would not allow this, and would cause extreme tire wear as well as other driveability issues.
Old 12-04-13, 04:08 PM
mike33
mike33's Avatar
A limited slip differential is what you would want for increased traction and street drivability... Check this link for some great info. https://www.clublexus.com/forums/is-...-my-is250.html
Old 12-04-13, 04:50 PM
Gville350
Gville350's Avatar
I HIGHLY recommend NOT to purchase or weld up either! You're cheapest alternative is a used IS300 or Supra or FS-R/BRZ LSD.
Old 12-04-13, 10:13 PM
2012IS250
2012IS250's Avatar
I would but I honestly cannot find any used LSD for under $400-500, I've searched on Craigslist and eBay, no luck
JBrady
40
12-26-20 11:05 AM
ShawnOk
09-11-16 10:32 PM
2012IS250
12-10-13 09:47 AM
JBrady
Performance & Maintenance
10-30-02 03:03 PM
Camshaft
Wheels, Tires & Brakes Forum
05-02-02 06:50 PM
Quick Reply: Difference between locking carrier assembly and welded diff?
