[Video w/ audio] Help. Strange noise from transmission area, 06' IS350 RWD Auto
2006 IS350 RWD Auto. Rattling sound coming from transmission area at idle and low speeds. Much worse in "D"rive and when pointing downhill. No performance issues whatsoever.
Video is of the open center console area, sitting at idle in D with brake on. I rev the engine towards the end. The rattling isn't this bad all the time. Worse when cold, I think.
I also inspected under the car. Didn't see anything. Couldn't pinpoint the sound from under the car because it wouldn't rattle in idle while I had the car up. I have a feeling I'm headed to the dealership soon haha
that's what I originally thought but there is nothing vibrating in the console. actually, it sounds like it is coming from under the shifter. that sure what could be under there that would make such a loud sound.
its something rattling against the shifter so i would suggest disassembling the shifter assembly and re assemble it, see if you see any loose parts that could be causing it. It sounds like a plastic rattle. Metal rattle or grinding creates a different noise all together
Does it make the same noise when you shift to N?
The reason i ask is because once inwhile while stopped in D, i get a knocking (or a donk donk donk donk) sound from my front passenger area. I've always attributed this to being lowered on AWD but now am suspicious. The sound goes away in Neutral though.
The transmission and engine perform flawlessly which leads me to think that maybe it is the shifter linkage. Might have to remove the exhaust to get it that though. Not sure.
How does it react once the car is up to operating temp? Im having a similar issue on cold start. When I put the car into drive at lower than operating temp, the trans seems to get pretty loud. Nothing at any other RPM or at all once warm, even on a warm startup. Just sounds like the trans is laboring. Ill try to get a video so we can compare the two.
2006 IS350 RWD
2006 IS350 RWD
Finally got back under the car today. Jacked up on all 4's and turned the car on in D with the E-brake on. I was able to get the rattle going while I got under the car. Found this:
http://imgur.com/a/uqKXF/all
You can see where the bolt was "pecking" at the floor board and making that noise. There were actually two that were like this but only one was making noise I think. Put new stainless steel hose clamps on it. Haven't driven on it a bunch but I pretty sure this fixed it.
