Looking at '07 is 350
Well guys, this is it!
I went to check it again, plugged it to a Toyota computer. Not a single error report from transmission, Airbags, ABS, Engine. No broken sensors. Just the one with the TPMS Check system, they deleted the code and we ran the car again and it didn't reappeared.
The only thing is that the A/C is not cool enough, that's 'cause the car is low on gas.
I went and checked it from bellow, everything ok down there and noticed a couple of things: It has Tein Coilovers! Only in the rear suspension, the front is stock suspension thought, but it makes it a little easier isn't?
I think' i'll bite the bullet on this one, it just need a little care on the interior, and i plan to replace some interior parts with the money i saved from buying the car and the mods that it has already.
^If you ask a Vendor on here that sells Tein items just for front coilovers, they SHOULD be able to source those for you. Just confirm which model coilovers it has before you purchase the fronts. You want a good, matching set. Not sure why only rears are on the car; perhaps the fronts were toast and were replaced by the OEM shocks. IDK.
