Nitrous 1/8 Mile pass
Old 04-06-14, 11:00 AM
  #46
Gville350
Gville350's Avatar
^Can you describe what you were doing and the exact situation where the trans didn't shift as it should have?
I can tell you that in rare instances (less than a handful of times since I've owned my '06 350) that in full AUTO mode I have managed to somehow reach the rev limiter in-between shifts; BUT, the trans DID shift by itself...unlike what like you mentioned.
Old 04-06-14, 11:24 AM
  #47
rayac88
rayac88's Avatar
Originally Posted by Is350nlm
For you ppl that have nitrous I was wondering if y'all have problems with the trans not shifting if you don't let out of the gas for a split sec. I have a zex wet kit on a 65 shot and if I don't let off it will hit the rev limiter and not shift till I let off a little.
Happens to me since I put my headers on. But it's never consistent. It could be the trans not shifting quick enough. Or the ecu not picking up fast enough to tell the tranny to change. Mine will hit 6500 and the rev limiter will kick in two or the times then it will shift automatically. Just my thought. But the Tranny might need some maintenance im almost at 100k on mine.
Old 04-07-14, 06:43 AM
  #48
Is350nlm
Is350nlm's Avatar
Say I am doing a 40mph roll in 2nd gear with the extra power button off and I go full throttle after I hit full throttel I put it in regular drive right away so the control moduel does the shifting for me. When it should shift to the next gear and I dont let out of the throttel just a little it will hit the rev limiter I don't want to stay in it when I'm spraying to find out if it will shift without letting off. If I'm not spraying it shifts fine with no hesitation.
Old 04-07-14, 11:05 AM
  #49
rayac88
rayac88's Avatar
Yea i wouldn't spray through the limiter unless you have a fail safe for when it hits the limiter. But even then its risky. Your driving it right but what about when you stop spraying at like 6200 6300 rpm keep your foot down through 6500 will it shift?
Old 04-07-14, 04:10 PM
  #50
Donkey
Donkey's Avatar
I've had a few instances when I bounce off the limiter on the unit but it shifts after a couple bounces. Like mentioned above, its very inconsistent, I've only had it happen a few times. I definitely think its the ECU not being able to send the "shift" signal to the trans fast enough.
Old 04-07-14, 04:28 PM
  #51
MyIS350G
MyIS350G's Avatar
damn thats quick!
I did 8.97 at Irwindale (The Pursuit 4)
Old 04-10-14, 07:37 PM
  #52
Is350nlm
Is350nlm's Avatar
I don't have any kind of RPM window switch so I don't know. I am going to order one and see what it does for me. hopefully it will work.
also are yall running any higher octane gas to run a 100hp shot?
Old 05-08-14, 08:05 PM
  #53
kamileon
kamileon's Avatar
My transmission does the same thing. Flushing out the fluid didnt help and it is at the correct level. The 6 speed is not fast enough to shift modified is350s. There has to be a reason beside fuel mileage that they use a 8 speed in the f sports.
Old 07-30-14, 10:46 PM
  #54
rayac88
rayac88's Avatar
any update on times donkey with that 75 shot?
Old 08-07-14, 02:05 PM
  #55
Donkey
Donkey's Avatar
No Unfortunately, I sold my baby and picked up a 2014 CT200h F sport. We'll see if the hybrid can handle a bit of nitrous lol
My dad and I have actually discussed installing the Unit on his IS350 for kicks, so once I do that ill post some times and install picks
Old 08-07-14, 11:15 PM
  #56
rayac88
rayac88's Avatar
if you dont get to put it to use and i keep my car, pm and ill buy the kit from you. DIBS! lol
Old 10-27-14, 07:52 AM
  #57
Is350nlm
Is350nlm's Avatar
Any of yall have problems with the car running bad the next day after spraying. Feels like it missing and shifting funny?
Old 10-27-14, 06:40 PM
  #58
Gville350
Gville350's Avatar
^Why? Have you experienced this?
Old 11-03-14, 05:29 AM
  #59
Is350nlm
Is350nlm's Avatar
Yes every time it doesn't happen right away but the next day after a 15 mile drive or so it starts to run rough I have had it to where i can't even drive the car because it wants to shuts off. I have to disconnect the battery for a while and then it will drive fine.
Old 11-03-14, 07:46 AM
  #60
scott1256c
scott1256c's Avatar
I know NOTHING of nitrous injection, so maybe this is stupid, but are you injecting before the MAF sensor? Could that be getting fouled?
Quick Reply: Nitrous 1/8 Mile pass
