Adding weights to the steering damper mod in 06 IS350
Old 09-30-13, 12:01 AM
Patsum
Patsum's Avatar
Default Adding weights to the steering damper mod in 06 IS350
I bought myself the steering damper kit from sewell and will install it this week.
I was wondering and saw a few people briefly comment but not go into detail. The steering damper is pretty much a 550gram weight on the center of my wheel. I want to know from those of you who added more weight via tire weights or weight tape. How did the extra weight change the steering feel?
I ask because I really dislike my IS350's steering. Very much so. Stock 17s and stock suspension and brand new tires and the steering just sucks. The car handles well but I am always fidgeting with the wheel on the highway and it gets tiresome. The car is aligned and drives straight but I'm always correcting or playing with the wheel and it's obnoxious over bumps. Doesn't feel highway stable and annoys me. I came from a 1998 LS400 and a 2003 Mini Cooper S so I have had the most light steering to very very tight steering on both cars to this...
How much weight did you add? Or how much would you add? And where did you put the weights? equally on both sides or in the center? How did it change the feel with more or less?
Thanks
Old 09-30-13, 10:31 AM
edgeucated
edgeucated's Avatar
Im not sure how much help adding weights to the steering damper would affect it, but since your's an 06, i think a much better mod for steering feel would to be an updated ECU.
The 06 had the worst steering ECU; you can get an IS-F steering ECU
Old 09-30-13, 11:05 AM
willSFP
willSFP's Avatar
I have always wondered the same. Coming from a G35 coupe, the steering on my IS has been pretty lifeless. I was thinking of adding more weight to my damper, but I don't want to mess with something that has been designed properly already. An IS-F steering ECU would be awesome
Old 09-30-13, 02:00 PM
viprtwo
viprtwo's Avatar
i'll have an ISF steering ecu up for sale in the next few weeks.
Old 09-30-13, 08:23 PM
Patsum
Patsum's Avatar
I'll buy it.
contact me
Old 09-30-13, 08:26 PM
edgeucated
edgeucated's Avatar
just a heads up, the f-sport steering and different IS-F years ecu will give you better feel too. Depends on what type of steering feel you want, you should research on the differences.
Old 09-30-13, 09:11 PM
willSFP
willSFP's Avatar
This thread gave me a clearer idea of the steering ECU's https://www.clublexus.com/forums/is-...ering-ecu.html
Old 09-30-13, 09:13 PM
Patsum
Patsum's Avatar
Thanks, I actually already checked that entire thread out. I just have to decide if the result is worth the money.
For now I will experiment with weights on my damper.
Old 09-30-13, 09:16 PM
nosurprise
nosurprise's Avatar
Some people said they feel a difference, some don't feel anything. I don't feel a difference. Your feel might vary.
Old 09-30-13, 10:01 PM
willSFP
willSFP's Avatar
Update us with the outcome. I'd love to have a heavier steering feel for cheap
Old 10-01-13, 11:25 AM
Patsum
Patsum's Avatar
I'll be sure to update. I think I have to add more weight to the center of the damper. Not the Edges. But I will try both ways and see the difference and report back.
Old 10-03-13, 01:32 AM
yungsters
yungsters's Avatar
I also have a 2006 IS350 with steering dampers and the 2012 IS-F Steering ECU.
The steering damper is noticeable at first but less noticeable after about a week. I only notice it now when I drive long distance (my palm does not get numb from bumpy roads anymore).
On the other hand, the ECU really stiffens up the wheel in PWR mode (does very little without PWR mode). I still feel the difference even though I've had it installed for almost, if not already, a year.
Old 10-03-13, 09:51 AM
edgeucated
edgeucated's Avatar
with weights added, im sure over time your body would re-adjust and you wont feel it for sure. This is because it's always in effect. The ECU changes the weight of the steering based upon a variety of factors, such as speed, so you'll never fully adjust to it, so you should always feel the steering being lighter or heavier at different times.
Kinda like how the steering is pretty easy to turn at very low speeds, but requires two hands at high speeds.
I would opt for the newer IS-F years or the F sport, because those apparently have the most revise steering
YotaCarFan
HS 250h Model (2010-2012)
08-10-10 06:56 PM
stanell1
11-27-09 09:06 PM
is350wh
09-07-09 08:50 PM
LEKSO
Maintenance
02-02-06 01:14 AM
KevinGS
10-29-05 12:51 PM
Quick Reply: Adding weights to the steering damper mod in 06 IS350
