static in radio
Old 09-17-13, 04:40 PM
hanadul
hanadul's Avatar
Default static in radio
Used rear defroster today and radio went to static! How do I fix this??
Old 09-19-13, 06:31 PM
ISFHEMS
ISFHEMS's Avatar
I had the same problem with mine a while back. The previous owner had tints, Lexus dealer removed them when they put the car on the lot and must have damaged the antenna in the process. The problem went away when I had the windows tinted again.
Check the antenna (which is built into the rear screen, if you didn't know) is not damaged and make sure the inside of the glass is clean. If you see a break in the antenna then it can be fixed fairly cheaply. I'll have a look for the product and post a link.
Old 09-19-13, 06:35 PM
ISFHEMS
ISFHEMS's Avatar
http://m.advanceautoparts.com/mt/sho...n_jtt_redirect
I know it says defogger repair but it works the same!
Good luck!
Old 09-23-13, 03:35 PM
ISFHEMS
ISFHEMS's Avatar
Any updates?
kmeehan
05-23-19 08:12 AM
lamar411
RX - 1st Gen (1999-2003)
05-30-10 08:31 AM
JCan37
02-12-09 05:53 PM
kevin333k
02-25-04 07:42 PM
Quick Reply: static in radio
