Rear Diff covered by Powertrain Warranty???
Hello
I was just wondering if the Rear Differential on my IS250 (08') covered under the original Powertrain Warranty? I have 60k miles on it.
I noticed some leaks that seems to come from either the drain bolt or the housing seal. It is dripping to where the exhaust pipe splits.
Thank you all,
Ken
Thank you all,
Ken
A little google goes a long way
Lexus warranty on powertrain... so it sounds like it is covered.
POWERTRAIN WARRANTY
The Powertrain Warranty is for 72 months or 70,000 miles, whichever occurs first. Except for the situations listed on the Basic Warranty page, this warranty covers repairs needed to fix defects in materials or workmanship of any component listed below:
ENGINE
Cylinder block and head and all internal parts, timing belt and cover, flywheel, oil pan, water pump, fuel pump, engine mounts, engine control computer, seals and gaskets:
TRANSMISSION AND TRANSAXLE
Case and all internal parts, torque converter, clutch cover, mounts, engine control computer, seals and gaskets:
FRONT-WHEEL-DRIVE SYSTEM
Driveshaft, axle, hub, bearings, seals and gaskets:
REAR-WHEEL DRIVE SYSTEM
Differential carrier assembly, driveshaft, axle carrier, axle case, axle bearing, axle shaft, seals and gaskets:
POWERTRAIN WARRANTY
ENGINE
98GS430
09-06-19 08:31 PM
jj813
IS F (2008-2014)
14
10-16-13 03:07 PM
Gville350
07-05-11 04:58 PM
