Fog light mod gone wrong?
Old 09-02-13, 01:00 AM
codenko
codenko's Avatar
Default Fog light mod gone wrong?
Hey guys,
So I followed the instructions here: https://www.clublexus.com/forums/is-...ghts-help.html
and everything still works...but to OEM spec (headlights and fogs don't work independantly)
I seem to be having the same problem pfdaxe did in page 3 of that thread. Any suggestions? I know I have the right wires spliced based on the threads information and the 12v from the green parking light wire is working correctly.
Thanks
Old 09-02-13, 02:41 PM
codenko
codenko's Avatar
Figured it out. For future modders, the two wires you need to cut are on the wire harness in the middle that disappears into a plastic tube...not wires that go into a harness.
Old 09-02-13, 08:29 PM
anthony206
anthony206's Avatar
Hey maybe you can help me out. I have an 09 is250 I follow the instruction for the god lighted but it didn't work for. I cut the light green with silver dot and the white wire from the middle connector. Connect to a rocker switch... Nothing happen. The fog light won't turn on with rocker switch I have.
Old 09-03-13, 01:52 AM
codenko
codenko's Avatar
Follow the instructions from the thread I posted in the OP. My 08 had a diff wiring harness from the DIY thread so I'm guessing that they changed them at some point. Use the lime green with silver wires and the green with red stripe wires.
Old 09-03-13, 08:29 PM
anthony206
anthony206's Avatar
So I connect the lime green with silver dot and green with red stripe together as one female connector and then one female for the white wire from the middle connector under the fuse box. After that run it into my firewall with a rocker switch ?
searchdev
10-20-18 12:32 PM
lostape45
02-26-16 07:53 PM
Riksgs808
09-13-13 01:18 AM
ohsogrim
03-18-13 08:33 PM
Braddism
04-24-06 09:59 PM
Quick Reply: Fog light mod gone wrong?
