Defective Headlight? Can't raise my low beam
Okay I have the 2012 headlights. So my passenger headlight was aiming a light too high so I tried to low it. Now I find that my headlight is pointing completely down. I have been rotating my screwdriver counter-clockwise, however its not raising my headlight. I don't know what I am doing wrong. I checked out other threads and I believe counter-clockwise with the screwdriver raises the light correct. Any help would be appreciate...
Not sure which way you need to turn but if your turning it counter-clockwise and its not doing anything have you tried just turning it clockwise to see if it does anything? I had a similar problem after I had my headlight housing painted satin black. I noticed my light beam on both headlights was off. One was ponited too high and the other too low. Well I was being lazy about it and waited a few days and am not sure when it happened but one day I just noticed that the light beam on both where pointing straight again. Not sure how it happened because am pretty sure i dont have auto adjusting headlights but maybe you'll get lucky and the same thing will happen to you.
Well I turned it clockwise and it loosened up the adjustment screw..I rotate it like 60 clicks...however the light seems to be stuck...is that possible? Its so annoying because my passenger light is just pointing down..
So I tried to grip the projector and manually moved the projector up a bit. I felt the adjustment screw moving, as I stuck my finger into the headlight. I just dont understand when the light keeps pointing down. I turned the adjustment screw right and then left and I feel it moving yet I dont feel the light moving up ughhhh...please help...I also noticed that some of the OEM paint in my housing is melting...
