I need a replacement OEM navigation for my IS250.
Old 08-29-13, 02:12 AM
unionper
unionper's Avatar
Default I need a replacement OEM navigation for my IS250.
So the ribbon that connects to the touch screen is broken, but i can't buy just the replacement ribbon from the dealership, so im forced to buy a navigation unit, broken or used, doesn't matter, all i need it this ribbon.
Does anywhere know i can find a broken or working navigation unit for 2nd gen IS
also checked the marketplace, no luck either.
Old 08-29-13, 06:22 AM
4TehNguyen
4TehNguyen's Avatar
this ribbon doesnt come with a replacement screen? Some people replace their screens to fix the frozen screen issue. You can buy the screen for $250 I heard
take a look in this thread, might help
https://www.clublexus.com/forums/is-...n-fix-diy.html
Old 08-29-13, 12:29 PM
whitebeast
whitebeast's Avatar
try to look here
http://www.ebay.com/sch/i.html?_trks...at=0&_from=R40
Old 08-30-13, 03:16 AM
unionper
unionper's Avatar
thanks for the reply, but i actually ordered a replacement touch screen from japan, and it still doesn't turn on.
the ribbon thats broken connects from the board behind the touch screen to the ups unit. i'm not sure if the dealership sells just this ribbon, i doubt it.
i believe this ribbon is the reason why my screen is not turning on, because i notice that one of the teeth on the very end of the ribbon was broken off.
Old 08-30-13, 07:21 AM
whitebeast
whitebeast's Avatar
If the cable failure, change your touch screen LCD should fix it. If connector (on UPS) is damage, you're out of luck! I don't think the cable is what you need cause the ribbon cable is included with touchscreen
Old 08-30-13, 03:42 PM
f111f444
f111f444's Avatar
Buy new screen on ebay. It is same as the OEM. I just changed mind and it work perfect. Good luck!
GS400NYC
02-04-23 02:50 AM
teamcalvin
IS F (2008-2014)
10-06-14 10:40 AM
rmittim
10-15-13 02:09 PM
skillvsluck
07-02-12 09:25 PM
Tcapone1
04-09-08 01:59 PM
Quick Reply: I need a replacement OEM navigation for my IS250.
