p0172 check engine light on
Old 08-19-13, 10:45 AM
i3urton
i3urton's Avatar
Default p0172 check engine light on
Please CL family please help. My 2007 is 350 has the p0172 error code and check engine light on. it says im running to rich. Just got my MAF sensor replaced. hope that does the trick. any one else with this issue.
Old 08-19-13, 10:49 AM
i3urton
i3urton's Avatar
https://www.clublexus.com/forums/sho...ighlight=p0172
Old 08-19-13, 12:34 PM
Gville350
Gville350's Avatar
Once you've done a tank on the new MAF, report back on your MPGs.
Did you reset everything by discounnecting the battery for 10 minutes?
Old 08-19-13, 02:26 PM
i3urton
i3urton's Avatar
how much is a new maf on sewell i couldnt find it.
Old 08-19-13, 04:22 PM
panda08
panda08's Avatar
normally MAF sensors don't go bad. Usually its the A/F or O2 sensors that go bad...
Old 08-19-13, 05:54 PM
p0lo8
p0lo8's Avatar
I had the same issue. It was one of A/F sensors.
Old 08-20-13, 10:55 AM
i3urton
i3urton's Avatar
https://www.clublexus.com/forums/rx-...el-sensor.html
is this the same or use as ref? for any one that diy?
sewell sells af sensor
http://is.sewellparts.com/accessorie...2006/5810.html
AdamProve
09-15-18 05:12 PM
b2884987
RX - 1st Gen (1999-2003)
07-04-16 08:26 AM
LEX1989
IS - 1st Gen (2001-2005)
26
12-22-10 02:44 PM
BartleDoo
Performance & Maintenance
08-12-10 07:58 PM
goldfish
04-13-10 06:51 PM
Quick Reply: p0172 check engine light on
