Issues with LED headlights...please help
Old 07-30-13, 06:58 PM
Vibes63
Vibes63's Avatar
Default Issues with LED headlights...please help
I just noticed that my LEDs on one of my headlights - 2012 isn't working anymore. All the other lights work however the led region isnt working? Could it be my fuse or wiring? I just don't understand why it stopped working...
Thanks
V
Old 07-30-13, 07:00 PM
MyIS350G
MyIS350G's Avatar
check the fuse first
Old 07-31-13, 09:53 AM
Vibes63
Vibes63's Avatar
Would just the led blow out just with the fuse? The headlight and turning signal work.
Old 08-01-13, 04:22 PM
Vibes63
Vibes63's Avatar
Anyone have a similar issue?
Old 08-01-13, 04:46 PM
ahmed24
ahmed24's Avatar
Does the LED strip work on 50% intensity? is it factory fitted or did you install these headlamps?
Old 08-01-13, 05:52 PM
Vibes63
Vibes63's Avatar
I installed it on my 2007 IS350. The LED light is dim, flinkering. It was working for a few months at 100% brightness. I have no idea what happened. The right headlight is 100% functional.
Old 08-01-13, 06:15 PM
ahmed24
ahmed24's Avatar
Sounds like something has gone wrong with the LED circuit, specially since it is working on 50% and flickering. How did you wire the 50% and the 100%, what power source did you use? how long have you had these installed?
Old 08-01-13, 07:00 PM
Vibes63
Vibes63's Avatar
These have been installed for 6 months. I went on a long road trip and they stopped working correctly. I wired it to be at 100% percent -all of the time. I can't find the picture I used. I am wondering if the wire is loose as the headlights and the turning signal work??
campfire
GX - 1st Gen (2004-2009)
53
12-28-20 10:38 PM
lilpub3
12-30-16 12:08 PM
Kenny88880
06-19-16 08:59 AM
silvaIS
10-08-11 09:51 AM
Jmags
01-03-11 04:53 PM
Quick Reply: Issues with LED headlights...please help
