best IS-F style front grille for the money?
Old 08-01-13, 09:05 AM
Downtuned
Downtuned's Avatar
I just ordered my grill for around 50 bucks. My only concern is where the emblem will be, it seems to be hollowed out, instead of there being an L shaped mold behind it. Will this be ok when installing the emblem?
http://www.ebay.com/itm/190861889987...ht_5528wt_1170
Old 08-01-13, 12:04 PM
mike33
mike33's Avatar
down,
Don't sweat it, I ordered the same one, it comes with the little "L" peace for the center. I was worried to when i ordered mine. Good luck
Old 08-01-13, 12:21 PM
Downtuned
Downtuned's Avatar
Originally Posted by scatpak
down,
right on!! you put it on yet? I'm gonna sand n' spray paint it and clear coat.
Old 08-01-13, 04:00 PM
mike33
mike33's Avatar
Yeah, it fits perfectly... I painted it with a dupli-color spray paint, in a factory toyota color called magnetic gray metallic. The color is a charcoal gray color with metallic flakes. I put on 3 coats paint, then 3 coats clear, no primer needed... I'm very happy with the outcome. Go to auto zone, or the like, and pick out a color that you like. You'll be pleased with the results. No sanding required either, just paint n clear.
Old 08-05-13, 07:41 AM
Downtuned
Downtuned's Avatar
Thanks man. I actually read this post after I bought my duplicolor paint, I was looking for the honda metallic color that other members used, however I believe I bought the same kind that you did. It stood out to me the most, and after 3 coats, it looks MEAN!! im gonna clear coat it today, just kinda nervous about taking off the emblem and reattaching it to the new grill. any advice??
btw, i used 1000 grit paper and sanded all 160 diamond grooves... it sucked..
Old 08-05-13, 07:48 AM
bob4256
bob4256's Avatar
Just use some 3M tape to put the emblem back on
Old 08-05-13, 05:07 PM
mike33
mike33's Avatar
The emblem comes off pretty easily, just gently pry on the bottom side with an old credit card or a plastic putty knife. Try not to use a screw driver or anything metal it may scratch or bend the emblem... Like Bob said you can use 3m tape. Clean all the old residue off the emblem, then cut the tape into small strips and place on the back of the emblem. Its 2 sided tape of course so leave the backing on one side of the tape. Once you have the tape strips positioned on the emblem you can remove the remaining backing and install onto the grill... Or you could use an adhesive type silicone. Good luck...
Btw : I Cant believe you sanded the whole grill, I skipped that step and went straight to paint lol
Old 03-19-14, 03:02 AM
MrBalistic
MrBalistic's Avatar
what I notice is that the is-f style grills on ebay have a little more spacings between the honeycomb design compare to the oem ones.
Originally Posted by RDIS250AWD
The mesh on the OEM is-f/f-sport grill is grey/silverish gunmetal
vs ebay its just plain black
I would imagine the ebay one is made of a cheaper plastic than oem especially with the price difference.
lawrence1
IS F (2008-2014)
03-15-17 12:42 PM
calvin2376
04-03-15 05:45 PM
is307
03-19-09 10:56 PM
Quick Reply: best IS-F style front grille for the money?
