How do you Reset Check 4WD Light for the 06' IS-250
Old 10-11-17, 02:01 PM
thuan33
thuan33's Avatar
Default How do you Reset Check 4WD Light for the 06' IS-250
I drive a 2006 Lexus IS 250 AWD, been trying to figure this one out, would appreciate any tips.
Thanks
Old 10-11-17, 02:28 PM
MikeFig82
MikeFig82's Avatar
Do you have different size tires on your car? Is the car in stock form?
Old 10-11-17, 07:27 PM
thuan33
thuan33's Avatar
I had same size tire but deference band of tires on the car, the two front tires are 40% used, the two rear tires are band new . I checked OBDII for fault code there are no fault code. yes the car is in stock form .
Old 10-13-17, 08:42 AM
MikeFig82
MikeFig82's Avatar
I searched the forums. Most of the problems I see are on the RX350. All with different fixes.
flattire
Wheels, Tires & Brakes Forum
17
02-03-14 06:16 AM
redmethods
09-18-11 06:07 PM
Hybrid-JD
04-13-11 05:04 PM
06lexichic
01-03-11 11:39 AM
Nicelex13
05-25-10 08:31 AM
Quick Reply: How do you Reset Check 4WD Light for the 06' IS-250
