Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - Second Generation
Sign in using an external account
Register Forgot Password?
Engine Oil Level Low Warning
Thread Tools Search this Thread
Old 07-07-13, 02:28 AM   #1
flyingjack
Trader Score: (0)
Default Engine Oil Level Low Warning
Hi guys,
I just got the warning "Engine Oil Level Low", pulled the dipstick out, check the oil level, it looks fine to me (the oil level is near the max level).
So not sure what happened here, maybe the sensor not working probably? I did my last service about 9k km ago.
Need some help from you guys, really appreciated.
Thanks alot
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
flyingjack is offline   Reply With Quote
Old 07-07-13, 08:08 AM   #2
Gville350
Trader Score: (9)
Gville350's Avatar
I would check the oil and the filter and see if it helps anything. If the warning icon still comes up, you more than likely have a bad oil level indicator.
__________________
'06 IS350 - 8.6468 @ 81.81MPH
Mods - SRI, BCRs, full GFX kit
Gville350 is offline   Reply With Quote
Old 07-07-13, 10:47 AM   #3
whitebeast
Trader Score: (5)
whitebeast's Avatar
Send a message via AIM to whitebeast
If the oil level flashing there is a change that your oil pump being bad. If it stay on, then oil level sensor problem. Make sure check oil level when your car is cold for more accurate.
__________________
whitebeast is offline   Reply With Quote
Old 07-07-13, 08:46 PM   #4
flyingjack
Trader Score: (0)
Quote:
Yes checked the oil level when the car was cold.
The warning showed in the middle of the dashboard (where normally shows the temp/gear position etc) for a couple of seconds then disappeared. and only poped out when was on the highway.
so guessing it's the sensor?
Old 07-07-13, 11:23 PM   #5
whitebeast
Trader Score: (5)
whitebeast's Avatar
you should check your oil pump. Sound like your oil pump is being bad. Check it out soon, i have same problem like that on my scion tc and end up blown my engine.
__________________
Old 07-08-13, 09:25 AM   #6
Speedy321
Trader Score: (0)
Default Warning
I have been having the same issue. I am taking mine in today and hopefully they can trouble shoot it.
Speedy321 is offline   Reply With Quote
Old 07-08-13, 12:08 PM   #7
RTIS250
Yes. I drove the LFA.
Trader Score: (9)
RTIS250's Avatar
RTornio RTornio RTornio RTornio
Send a message via AIM to RTIS250
Typically with a bad oil pump, you would get low oil pressure warnings, not low oil level warnings.
__________________
Current Rides:
2014 Lexus GS350 FSport
2007 Toyota Tundra SR5 5.7 TRD 4x4
2010 Toyota Sienna Limited
2005 Subaru WRX STi
RTIS250 is offline   Reply With Quote
Old 07-08-13, 12:41 PM   #8
whitebeast
Trader Score: (5)
whitebeast's Avatar
Quote:
I don't know about lexus (haven't have that problem but on scion tc) there is no oil pressure warning light. If oil level is low, it will stay solid. If it bad oil pumping, oil level warning light will flash. I haven't read user manual of lexus yet but you should find information there (about oil level indicator light)
OP did mention about if only show up on highway that's the reason i think oil oil pump. Anyway, double check to be sure is always good thing to do.
__________________
Old 07-09-13, 12:02 PM   #9
Gville350
Trader Score: (9)
Gville350's Avatar
Are you sure you have the right dipstick? I know this seems odd, but I got this ALOT when dealing with Honda motors, since alot of theirs are visiably the same, but different length sticks (thus affecting the TRUE oil level).
I believe within the last month I've read about an actual oil-level sensor on the 2IS model; could be wrong, but it's what I'm remembering probably from a late-night web session.
__________________
Old 07-09-13, 10:20 PM   #10
RTIS250
Trader Score: (9)
RTIS250's Avatar
There is only one dipstick on the ISx50...
There is an oil level sensor on the ISx50, as well as an oil pressure sensor.
__________________
Current Rides:
2005 Subaru WRX STi
Old 07-10-13, 12:01 PM   #11
L3XOTIC
Trader Score: (0)
L3XOTIC's Avatar
myparkwayauto Azar04 instagramp0lice
It can be either the oil pressure sensor or the oil pump itself based off your description of the problem.
__________________
2002 Crystal White GS300 **SOLD** & 2007 Starfire Pearl White IS250 AWD (Wifey's) - Black Roof Club Member(s)
L3XOTIC is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Car burning oil ecko1211 GS - Third Generation 15 04-01-14 07:37 AM
Engine Oil Gone Missing! shiny250 IS - Second Generation 12 11-30-13 06:55 PM
Oil Dipstick Level Check mandyfig IS - Second Generation 1 11-19-13 10:35 AM
Oil Warning Light esucaris1 ES300 and ES330 0 10-28-07 09:21 PM
Tags
09, 2002, car, club, engine, es300, is250, level, lexus, lexuslow, light, low, oil, sensor, warning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2015 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
