TPM : LOW TIRE , But they aren't !
Hello CL members
Starting from a week ago , 50% of the times I start the car in the morning it gives a low tire warning.
my tires are filled with nitrogen and the pressure is between ( 35-38)PSI in all of them.
Keep in mind that the system would show the same message if it lost detection of one of the sensors !
this my indicate a low TPM sensors' battery right?
but how to replace the battery and how can I know which one needs a replace before opening the tire ?!
thanks
thanks
As far as I know batteries are not replaceable, there are a few sets of TPMS sensors in the classifieds right now. http://www.tirereview.com/article/86...batteries.aspx
spare tire does not have a sensor. its a compact donut one.
I would recommend to check all tires when they are cold like in the morning after car sits over night. after you checked them and made sure its 35 psi front and 38 psi rear, you have to reset the TPMS light by using the buttons on the left side of the steering wheel. hold the reset button until the TPMS light flashes 3 times then let go. after that don't turn the car off for at least 10 mins.
Hello CL members
thanks
thanks
First off what year is the car? tpms battery life is 5 - 7 years. if it were a battery problem then it would completely stop working or it would be intermmitent which is what it sounds like. Batteries can not be replaced, sensors can.
the first thing to do is go to a place that can do a dtc to determine what the problem is. If it is a battery problem you may want to replace all 4 sensors if they are old.
Wow. Wondering how washing the car fixed it...
My car did that from day one. Always the right front gave off the signal. AND it was always low. Nothing in the tire to cause it. So one day after I drove it kind of rough it stopped.
I think that the tire bead wasn't seated properly and that's where I was losing air. Good thing nothing bad happened.
Super Moderator
As Panda said, no TPMS on spare.
Hope it's off for good, but my expectation is that one of your tire pressures in marginal, and that the light may come back on the first chilly morning.
Hi
I have the LOW TIRE light on all the time now.
I believe it has something to do with washing the car.
It has been on for 3 weeks now and I can't figure out where is the main unit or which sensor is defected :\
