factory HID low beam question.
Old 07-05-13, 07:14 PM
blancois
blancois's Avatar
Default factory HID low beam question.
i have a 2010 is250 and i just upgraded the low beam (with factory hid) to 6k and fog light to HID. However, im not happy with light output form low beam, its too dim. i was thinking of upgrading low beams to aftermarket hid kit, what bulb should i use? thank you for your help.
Old 07-05-13, 07:30 PM
Nikon
Nikon's Avatar
6k is going to be less output than the factory 4300k you removed. you didn't really upgrade the low beam. you just got a new bulb with a bluer color temperature and therefore less output. if you want brighter, you're going to have to go back to the factory HID. i think phillips has a more expensive 6k available that might be a little bit brighter. that might be your best bet if you want slightly brighter 6k light output but probably won't be as bright as your OEM hid bulbs you had in the car already.
Old 07-05-13, 09:34 PM
greyIS25
greyIS25's Avatar
I agree with Nikon, the higher the number, the less useable light you will have. Stick with stock 4300
Old 07-05-13, 10:15 PM
jdmSW20
jdmSW20's Avatar
hit this one on the head. the higher temp you go, the more light output you are losing. my car had 8K bulbs in it when i bought it and that sucked honestly. i went back to 5k xenon depot bulbs because i didnt want to pay the price for the oem 4300K.
but 4300 by far will be the most light output you are going to get. i did 3k in the fogs and love it
Old 07-06-13, 08:20 PM
blancois
blancois's Avatar
thanks for the input guys. im gonna replace the stock bulbs in the AM
EthanV
04-08-18 09:46 PM
Is350Josh
04-22-13 11:31 AM
Xenon9
09-22-07 02:39 PM
Tropheus
09-12-06 08:45 AM
brian3268
Lighting
12-12-02 01:21 PM
Quick Reply: factory HID low beam question.
