Go Back   Club Lexus Forums > Lexus Model Forums > IS Models > IS - Second Generation
Sign in using an external account
Register Forgot Password?
Help: Jack and Jack Stand Points
Thread Tools Search this Thread Display Modes
Old 07-03-13, 10:38 AM   #1
Hbhandal
Trader Score: (3)
Hbhandal's Avatar
hbhandal PGADuckOnQuack hbhandal hbhandal
Default Help: Jack and Jack Stand Points
I needed some help jacking up my is250, I can't get my jack to the bottom jack points , so I tried to jack it from the side jack stand points and it bent the lining is this normal? And is it ok to jack up the car from the side jack stand points ? Also since the lining bent I'm worried that the jack points aren't that strong is it safe to place the jack stands there or should I place them in a different place. Thanks for any help.
This ad is not displayed to registered members.
Register your free account today and become a member on Club Lexus!
Hbhandal is offline   Reply With Quote
Old 07-03-13, 10:46 AM   #2
zmcgovern4
Trader Score: (0)
zmcgovern4's Avatar
AttentiontoDetailingPeoria zmcgovern45
You need to use a jack/jack stand pad to provide support so you do not bend the metal tabs at the jack points.
http://www.harborfreight.com/2-piece...and-95952.html
Some people will take a piece of hard rubber, like a hockey puck, and cut a groove in it for a DIY solution.
Make sense?
__________________
Megan EZ Coilovers|Trunk Lip|Roof Spoiler|Redouts|M2 Axle Back Exhaust|CF Vinyl Interior|GFX Sides
Xenon Depot 6000k HIDs & LEDs|MRR GF07 19x8.5+35/19x10.5+40|Hankook V12 235/35 & 275/30
I <3 Detailing
zmcgovern4 is offline   Reply With Quote
Old 07-03-13, 12:01 PM   #3
edgeucated
Trader Score: (4)
edgeucated's Avatar
our jackpoints are horribly weak. ive crushed two completely flat. i now use the hockey puck idea but i made mine out of wood.
__________________
| 06 Crystal White IS350 | KW V3 | WALD lip | Red Outs | VLed DRL | 35% tint | 6k Garax HID | 3m Carbon pillars | IS-F rear conversion | 3M Diffuser w/ molding surround | AIT carbon splitters & rear canards | K&N filter | black carpet conversion | IS-F steering damper | Hella Horns | F-sport sway bar | Jun-TW |
Navi, ML
edgeucated is offline   Reply With Quote
Old 07-03-13, 12:10 PM   #4
zmcgovern4
Trader Score: (0)
zmcgovern4's Avatar
The jack points are made to be used with the 'flat tire' screw jack that is stored by your spare tire... they work perfectly with that. They are not meant to be used with a standard floor jack without a pad of some sort.
__________________
I <3 Detailing
Old 07-03-13, 01:17 PM   #5
GiantsFan
Trader Score: (8)
GiantsFan's Avatar
Giantsfan7490 Giantsfan7490
Get some 2X10s and make a ramp ... then drive your car up on them so your Jack can reach the center jack points
Here is a pic I got off google images ... I made 2 just like these and they work great
__________________
IS250 - Painted Engine Covers - F-Sport Intake - Megan Mids - Lexus HKS exhaust - BC Coils - F-Sport Sways - Forgestar F14 - IS350 BBK/Stoptech Drilled Rotors - F-Sport Grille - GFX Lip - CF Splitters - CF Rear Canards - 5000k Lows & 3000k Fogs - Fog Light Mod - Black Emblems - NorCal/CL Plate Frame - Roof Spoiler - CF Decklid Spoiler - IS-F Tails W/ LED Blinkers - IS-F CF Interior - IS-F Steering Damper - F-Sport Shift **** - Sport Pedals - OEM iPod Kit - LEDs Everywhere
GiantsFan is offline   Reply With Quote
Old 07-03-13, 02:16 PM   #6
azfsprt
Trader Score: (3)
azfsprt's Avatar
Quote:
Almost all cars these days have them. If you bend the little tab you are ok, those jack points are double walled for that reason so there is the extra support.
As for the jack points I put my jack a little bit to the side of those tabs and jack the car from there. Those tabs are where I put my jack stands at. I couldn't find a jack point the middle of the from frame because its covered with all the plastic underbody (does the f-sport only have these?).
azfsprt is offline   Reply With Quote
Old 07-03-13, 02:18 PM   #7
azfsprt
Trader Score: (3)
azfsprt's Avatar
Where is the center jack point? I can't find mine its covered by my plastic underbody....
Old 07-03-13, 02:51 PM   #8
quick123
Trader Score: (2)
quick123's Avatar
There is no "center" jack point...only ones are right behind the front wheels and right in front of the rear wheels, and all this information is located in your owner's manual
__________________
2006 IS350 - SGM w/ Black, Luxury Package, NAV w/ ML, 19" FIVE:AD S5:F or 19" AME TM-02 - depends on my mood , Ksport air shocks, Accuair e-level & i-level, FIVE:AD front lip, GFX sides, MyRide diffuser, Wald rep spoiler, K&N filter w/ JoeZ intake, PPE headers, JoeZ PTS full race exhaust, EBC redstuff pads, Power Slot rotors, F-Sport sways, Megan arms, ISF tails, CF engine covers, Cusco brace, Amsoil, Motul...
quick123 is offline   Reply With Quote
Old 07-03-13, 03:09 PM   #9
GiantsFan
Trader Score: (8)
GiantsFan's Avatar
Quote:
By center jack points I meant the two you are talking about as they are in the center line of the car (and not on the sides)
__________________
Old 07-03-13, 03:21 PM   #10
quick123
Trader Score: (2)
quick123's Avatar
Pics are always better than words so there is no confusion...quick google search found this, yea it's a IS300, but it is the same on the 2IS
Help: Jack and Jack Stand Points-image-997445677.jpg
__________________
Old 07-03-13, 03:25 PM   #11
zmcgovern4
Trader Score: (0)
zmcgovern4's Avatar
Click the image to open in full size.
Here is the ISX50
Searching the forum you would have found several other threads already in the first place...
http://m.clublexus.com/forums/showthread.php?t=624132
http://www.clublexus.com/forums/is-s...-on-is250.html
__________________
I <3 Detailing
Old 07-03-13, 03:27 PM   #12
1sWt2GS
Trader Score: (5)
1sWt2GS's Avatar
pretty sure your manual covers this
__________________
2002 Millennium Silver Metallic Sport Design
All Stock
If you got a speeding ticket... You're not low enough.
// \\ All SHOW no GO
1sWt2GS is offline   Reply With Quote
Similar Threads
Thread Thread Starter Forum Replies Last Post
Propper procedure for jacking up vehicle and using jack stands LexBrett SC 430 11 07-01-14 10:20 AM
Jack and Jackstand Help TakaM IS - Second Generation 24 07-28-13 12:18 PM
Jacking up a car one side at a time ISmak4 IS - Second Generation 5 03-25-13 03:31 PM
Proper way to jack/raise one entire side Tact ES350 (2007 - 2012) 15 06-16-12 12:26 AM
Jacking Points on an ES300? myztikal47 ES300 and ES330 2 12-22-06 02:18 PM
Tags
2006, 2010, 2013, 250, back, clubs, forum, gs, is350, jack, lexus, place, point, points, safe, spots
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Join ClubLexus
Copyright © 2000-2008 Internet Brands, Inc. All Rights Reserved
Privacy Policy | Disclaimer | Terms of Use | JOBS
Get all contact info
