stock camber wear help
Old 06-02-13, 08:02 PM
panda08
panda08's Avatar
Default stock camber wear help
is it possible to adjust our stock suspension to eliminate the factory negative camber wear? it sucks having to buy 1 tire because my steel cords are showing, but still have 5/32 tread left.
Old 06-02-13, 08:45 PM
Dawa
Dawa's Avatar
are you sure its not due to toe in, which wears tires similar to negative camber
Old 06-02-13, 09:51 PM
panda08
panda08's Avatar
yeah, I had my alignment done after I lowered it with h&r springs.
Old 06-02-13, 11:55 PM
Nikon
Nikon's Avatar
are you rotating tires?
Old 06-03-13, 01:44 AM
Sango
Sango's Avatar
Did you consider changing the bushings?
The reason is under the braking, the stock bushings deflect to too much which causes the excessive inner wear. This is where the ones from FIGS could resolve this.
https://www.clublexus.com/forums/is-...eo-inside.html
http://shopfigs.com/v1/index.php?rou...product_id=138
Old 06-03-13, 06:13 AM
bob4256
bob4256's Avatar
You cant adjust camber without a camber kit. As long as you get your toe to as close to 0 as possible, you should be fine
Old 06-03-13, 12:08 PM
Gville350
Gville350's Avatar
How long (# of miles) have you had those tires?
How long (# of miles) have you been on those tires since the spring install?
After the alignment, what are your toe and camber settings?
What tires do you have?
Old 06-04-13, 11:26 AM
panda08
panda08's Avatar
I cant, I have OEM staggered wheels
Ive had the tires for about 15000 miles
I don't remember the mileage when I installed them, but its been about 6 months
my tires are the OEM bridgestone turanzas
Old 06-04-13, 11:32 AM
Deegee
Deegee's Avatar
listen to this guy, he speaks the truth.
More than likely the tire wear is coming from the toe and not really the camber, but of course go have it checked and have them zero in the toe.
Old 06-04-13, 12:45 PM
Gville350
Gville350's Avatar
You CAN have the tires dismounted off the wheels and re-mounted onto the opposite sides...but only if the tire's tread pattern allows for it.
By the way, it is the fronts huh? The 2IS model tends to have a natural, agressive front camber/toe setting from the factory. Some say, tire-dependent, 15k miles is actually normal.
Old 06-05-13, 06:22 AM
shaolin
shaolin's Avatar
your next option is to buy directional tires, where you can flip them and cross rotate. This wa you can wear the other side to keep it balance.
Old 06-05-13, 07:24 PM
panda08
panda08's Avatar
I just bought new tires, gonna have an alignment done either Friday or Saturday.
yeah, the fronts were bad. rear actually isn't bad at all. I replaced all 4 tires today anyways just so I could have the same "grip" front and rear.
I bought some Bridgestone Potenza S-04's today. Looks like ill be cross rotating my front wheels or maybe all my wheels to see what happens.
chris621
04-12-15 05:33 PM
Toxicxk23
12-29-12 09:09 PM
azkaty
08-03-10 08:59 PM
VinnRock
IS - 1st Gen (2001-2005)
03-19-09 03:03 PM
SPEED&ECO.
01-28-07 02:40 PM
Quick Reply: stock camber wear help
