DIY Fusible Link Removal?
Old 05-14-13, 04:47 AM
The1Ghost
The1Ghost's Avatar
Default DIY Fusible Link Removal?
Does any1 know how to remove the fusible link part # 82620-30170 from the actual fuse box located right infront of the battery? i recently switched batteries and accidentally did it wrong which caused me to blow a the fusible link. can someone help with a DYI step by step and pix if so process. Ive searched all over and can not find anything. thank you in advance
Old 05-22-13, 06:24 PM
genaos11
genaos11's Avatar
Your best choice maybe solder the fuse u blew that just a guess
Old 05-22-13, 08:43 PM
vboi4life
vboi4life's Avatar
you mean the one have clear cover.i never take it out but i read somewhere they say you can pop the clear cover and there are 2 10mm bolt.you get remove it to take it out
Old 05-24-13, 08:29 AM
The1Ghost
The1Ghost's Avatar
i tried that, and still re blows it again.
Old 05-24-13, 08:30 AM
The1Ghost
The1Ghost's Avatar
Yes the fuse block with the clear cover, and i tried that but there actually more to it than that, thats why i can figure it out.
Old 05-24-13, 11:30 AM
genaos11
genaos11's Avatar
I found this on Sewell if you hve to replace the fusible link any luck removing it?
http://is.sewellparts.com/oem-catalo...S250-2008.html
Old 05-27-13, 07:37 AM
The1Ghost
The1Ghost's Avatar
ive been tryin for a few days and cant seem to figure it out, there something in the bottom holding me back from gettin it out.
Old 07-08-13, 10:41 AM
Davinchitx
Davinchitx's Avatar
I have been searching everywhere online. I have the same problem blew the fuse after installing battery backwards. How do you remove the block? I have spent hours upon hours trying. At least now i know which part number I need to get.
Old 12-01-13, 09:17 AM
Hector2992
Hector2992's Avatar
Im in the same boat lol how did you guys remove it ?
Old 12-01-13, 04:17 PM
Hector2992
Hector2992's Avatar
No one ??.....
Old 12-01-13, 07:19 PM
The1Ghost
The1Ghost's Avatar
I figured it out but it's a process, it's very do able.
Old 12-01-13, 07:35 PM
Hector2992
Hector2992's Avatar
I tried my best to take it out today but I didn't get very far...after removing the 10mm bol,clear cover ect..what comes next "? Did you have to replace the whole thing ?this is what happened to mine
[IMG][/IMG]
Old 12-02-13, 05:55 AM
The1Ghost
The1Ghost's Avatar
ok so basically theirs tabs that you have to disconnect between all that look carefully. your gonna need some real thin long flat head about two of them. once you start disconnecting the tabs you start to pull up and everything starts to come part. lemme kno if this helps
Old 12-03-13, 08:25 AM
Hector2992
Hector2992's Avatar
Well been at it for a couple of hours with no progress..am I suppose to unbolt the whole thing ? Or just push the tabs in ?
[IMG][/IMG]
Old 12-03-13, 12:45 PM
The1Ghost
The1Ghost's Avatar
Yes those tabs theres like 7-8 of them all around the white fuse and blacks boxes. the craziest things also is you literally have to basically take out the other 2 boxes than the white one. since its all layered in like a puzzle in a L shape form
Quick Reply: DIY Fusible Link Removal?
