Transmission Shifter Noise
Old 05-08-13, 04:10 AM
JohnLX300
JohnLX300's Avatar
Default Transmission Shifter Noise
I wanted to know if anyone else has this same issue and/or have gotten it fix. Whenever I start my '08 IS250 RWD, and go to put it into any gear from P to D or P to R or R to P, you can hear the clanking as if something is slapping up against something else. It is a metal to metal noise. Car has about 58k now. Anyone experience similar noises?
Old 05-08-13, 12:58 PM
Gville350
Gville350's Avatar
You only hear the noise putting it into Park or out of Park? Does it do it when the engine/trans is cold or hot or both?
Old 05-08-13, 01:29 PM
Chrisyyo
Chrisyyo's Avatar
I get that when parked uphill going from P to R occasionally & D to P, IMO just try to be gentle with the **** & it will be less loud ive learned. Nothing drastic just a little less loud.. as far as being worried about it I dont think its doing any harm most cars do that when shifting if you listen close enough.
Old 05-09-13, 12:39 PM
Gville350
Gville350's Avatar
Could it not be the Shift Lock mech?
Old 05-09-13, 06:34 PM
triple_c
triple_c's Avatar
I don't have any noise when shifting from P unless I'm parked on an incline. Try putting your car in neutral first, bury the parking brake, take your foot off the brake, and then shift to park.
Old 05-09-13, 06:43 PM
GoGiantsNJ
GoGiantsNJ's Avatar
I agree with putting the parking brake on if on an incline. My driveway has a steep incline. One time I forgot to depress the parking brake and I did have a clunk when I put the car into reverse.
The stress on the transmission is much less with the parking brake on if on a hill
Old 06-10-13, 12:51 AM
SGMIS3
SGMIS3's Avatar
The problem is that the transmission mounts are wearing out. Needs to be replaced.
Old 06-10-13, 05:22 AM
B16da9
B16da9's Avatar
If he's correct it's covered under the powertrain warranty.
napbnico
04-02-19 03:28 PM
flashes23
05-20-17 01:40 AM
SynicalVip
06-11-14 06:20 AM
mp33er
RX - 3rd Gen (2010-2015)
06-29-13 09:43 PM
oogster
Performance
01-14-04 02:08 PM
Quick Reply: Transmission Shifter Noise
