Help: ISF Exhaust Outlet Dimensions
Old 04-23-13, 08:39 AM
DVIOUS350
DVIOUS350's Avatar
Default Help: ISF Exhaust Outlet Dimensions
So a couple of weeks ago, I damaged my rear bumper and all clips are now broken. I tried using adhesive to hold the clip but it is still coming apart.
The option is to get a exact rear replacement or get another bumper (ISF Style). The problem is that I have the HKS Hi-Power exhaust and wasn't quite sure if it will line up with the bumper's exhaust outlet.
So for those that have an ISF, can you reply with these dimensions
A. Vertical Dimension from the bottom of the trunk to the top of the outlet
B. Horizontal dimension from the side of the trunk to the far side of the outlet
C. Vertical dimension of the outlet
D. Horizontal dimension of the outlet (neglect the angle)
My guess is my HKS is sitting too low but this is worth a shot. Worse comes worse, I'll replace it with the same one.
Thanks
BLKLEX
Old 04-23-13, 09:35 AM
vapid2323
vapid2323's Avatar
I might be wrong but, why not cut the HKS tips off and put the ISF tips on the HKS?
I don't think that would change the sound much would it?
Old 04-23-13, 10:08 AM
Sffd103
Fire Slayer
Sffd103's Avatar
I think even if you do get it in there the hole is huge compared to the ISF huge square hole.
Old 04-23-13, 10:09 AM
1sWt2GS
1sWt2GS's Avatar
why would he want to cut into his HKS exhaust!
Old 04-23-13, 01:38 PM
DVIOUS350
DVIOUS350's Avatar
@SFFD. Yea from one of the pictures I found, it seemed like the holes is alot larger than the exhaust making it look tacky. What I'm going for is the look of the ISF with a tanabe exhaust.
I'm not going for the ISF look but there aren't many full rear bumper replacement (saw the VIP bumper) and not really wanting to put out a couple hundred just to have the same bumper. The better rear bumpers runs upwards of 1000 before labor and paint.
ModInJapan
CL Vendor Products for IS-F
12
07-13-16 09:09 AM
eclipsegst
07-10-15 07:41 AM
Kramer
10-11-12 04:08 PM
g_abac
09-12-10 03:25 PM
Quick Reply: Help: ISF Exhaust Outlet Dimensions
