Rear windshield spoiler need help
Old 04-18-13, 09:57 PM
DaveLexus
DaveLexus's Avatar
Default Rear windshield spoiler need help
hey guys i just put on a rear windshield spoiler and i used the 3m tape they sent me now its still on the car but i noticed it seems like its peeling off not sticking to the window anymore and i want to know is there any tape out there better then 3m or what should i do to help keep it on there thanks
Old 04-18-13, 10:08 PM
2slixx
2slixx's Avatar
Sounds like you didn't clean the windshield properly... Did you use adhesive promoter? You can always remove clean/ re-apply 3m tape. Mines stayed on damn well. Someone tried to pry it off with a screw driver and failed.
Old 04-18-13, 10:27 PM
Initial G
Initial G's Avatar
Did you use the 3M tape that holds up to 5lbs (dark gray with a red back)?
If you did, the spoiler should be firmly in place and not loose. I've had my spoiler installed with just 3M tape and it hasn't moved in over 1.5 years and it has gone thru various car washes and bad weather. If the spoiler is loose, just remove it and install it again. Remember to clean the rear glass before install. I know that some other members have used a product called loctite and had good reviews of it. Good luck on your reinstall.
IS2FIFTY
IS2FIFTY's Avatar
make sure you clean the surface well
Old 04-18-13, 10:41 PM
2genIS
2genIS's Avatar
your correct... mine holding up pretty well w/ 3m... just re-tape again
Old 04-22-13, 07:27 AM
DaveLexus
DaveLexus's Avatar
Okay thanks alot guys I thought I cleaned it well but looks like I didn't ill use that product thanks!
Old 04-22-13, 08:08 AM
B16da9
B16da9's Avatar
Clean the top part of the glass with alchol and wipe clean then use the adhesive promoter. Once you do that the spoiler should be on tight.
Old 04-22-13, 11:15 AM
bob4256
bob4256's Avatar
Never had an issue with my roof spoiler, its held up for over 2 years. Make sure you clean the glass and it should stick with no problems
Old 04-22-13, 11:56 AM
KillaIS250
KillaIS250's Avatar
Never had a problem with mine for 2 years either. Like the other said though, you have to make sure to clean the glass (I used a glass cleaner and then alcohol to clean it properly) and then install it. It also helps to do it on a hot day, I found it sticks better if the surface is hot.
eagle
01-03-07 05:26 PM
delmo
GX - 1st Gen (2004-2009)
02-09-04 09:49 AM
02RX
RX - 1st Gen (1999-2003)
12-11-01 09:38 PM
Quick Reply: Rear windshield spoiler need help
