Navigation touch screen problem
Old 04-17-13, 02:25 PM
f111f444
f111f444's Avatar
Default Navigation touch screen problem
I believe there should be a thread on here already ask about touch screen issue but after I did a search I think the issue on my touch screen is different because my screen still on and I still can move the map around when I touch the screen except all the buttons showed on the touch screen aren't function. If I still can move the map around that mean my touch screen still good right?
What happen is my friend install the airbag for me and after he finished installed, I found out that my navigation touch screen isn't function anymore. He told me he never touch the navigation screen, all he does is unplug the battery and do wire for the air suspension. So i'm not sure what went wrong.
Have anyone seeing this issue before? Is there anyway to fix this or I have to replace a new touch screen like other said on the other thread?
My car is IS350 2008 model
Thank in advance!!!!!!
Old 04-17-13, 06:13 PM
Gville350
Gville350's Avatar
Can you only access the map function? Can you use other functions and use those buttons on-screen?
Old 04-18-13, 03:58 PM
f111f444
f111f444's Avatar
Non of the buttons on screen functions, only the hard button work.
I found this link and hoping this is the same issue on my.
https://plus.google.com/photos/10852...593?banner=pwa
Old 04-18-13, 04:47 PM
Gville350
Gville350's Avatar
Sounds like the normal NAV screen failure...technically the ribbon, but you get what I mean.
MickeyS
GX - 2nd Gen (2010-2023)
07-12-15 06:40 AM
amillion
08-02-14 01:26 PM
ATL_AFW
05-20-12 07:07 PM
lkuo
RX - 1st Gen (1999-2003)
07-27-04 07:37 AM
Quick Reply: Navigation touch screen problem
