LED parking light swap troubles
Old 03-12-13, 04:20 PM
SeanO
SeanO's Avatar
Default LED parking light swap troubles
Swapped out my stock parking lights with some white LED's to go with my hid lows and fogs.. everything went well.. the LED bulbs work just fine but now my dash cluster is lit up with lights.. check engine light.. big exclamation mark.. traction control light.. I swapped the bulbs they are in and working.. anybody else have this same problem?! i have a scanner i can hook up and run to find the problem i was just wondering if someone else had this problem..
Old 03-12-13, 10:41 PM
Nikon
Nikon's Avatar
from just LED parking lights?
Old 03-13-13, 10:59 AM
sm1ke
sm1ke's Avatar
Maybe it has something to do with the different voltage or whatever it is that the LED lights operate on. I know that with LED turn signal bulbs you have to get a a resistor for each bulb or install/modify your existing flasher relay to stop them from causing hyper-blinking issues and stuff.
Old 03-13-13, 11:22 AM
SeanO
SeanO's Avatar
it fixed itself haha.. hopped in it this morning to tour to work and no lights.. gonna scan it anyways
hon3kong
RX - 4th Gen (2016-2022)
115
02-02-23 08:12 AM
ahynot
11-08-21 06:57 AM
LS2k
07-10-21 04:30 PM
3GSShoe
06-23-18 01:30 PM
rclab1
01-12-08 11:16 AM
Quick Reply: LED parking light swap troubles
