Awd IS250 with ISF rims
225/35/19 is fine for the fronts. It will be too small to put that size on the rears. Generally people put 255/35/19 on the rears with the IS-F wheels due to the rear being a slightly wider rim.
Will have pics probably by the end of the week but I don't have an AWD IS. I've got a RWD IS250. I'm just waiting on some tyres to go on.
Otherwise do a search around here, plenty of pics of IS with IS-F wheels
I went to get my tires installed 225/35/19 and 255/35/19 and the tire installer said that set up will not work because of the AWD on the is250? Is this true? I've read all along that the tire size would work. Any input?
[QUOTE=laobo979;7820507]Yes 255-35- will not work on awd it will run faster then your front wheel. You need to run 255-30 series that works alot better. Stock diameter 24.97 & 255-30 is 25.03 diameter which is near to stock you can get.[/QUOTE
So I will need 235/35/19 in the front and 255/30/19 in the back?
