car takes longer to start (slow cranking)
Check your battery to see if it is 12V. If it's below 12V, you would need a new battery. Sometimes starter is also an issue, so make sure you check the starter too
Battery issue for sure, is your brake peddel hard sometimes in the morning too? That will be caused low battery or low amps. Call AAA they will test it and give you a better warranty then lexus
i was battery issue. the car die on me this morning. replaced with a new battery, it's all good now. i had to remove the outer battery bracket in order to connect my new battery up perfectly. i noticed the OEM Panasonic battery is smaller, therefore it needs that plastic bracket.
We put a Battery Brain on our battery, comes with a fob. Now we kill the battery every time we turn off the engine by clicking the FOB. No problems with the parasitic leak however the clock has to be reset each time. The battery brain is used at marinas on motor boats. It got too hard to find the battery drain after to put $1000 in thinking we fixed the issue.
JohnnyGee (03-13-23)
To bad you couldn't resolve the real issue.
GL
debor300 (09-22-22)
The MPX B computer has caused many parasitic loss issues. Cheap on fleebay but hard to point the fingers at and may not bear fruit with the shot gun approach.
