Seeing is Believing: 358rwhp, 400rwtq Supercharged IS350 (DYNO'd)
Old 01-27-15, 12:45 PM
  #166
jordan350
jordan350's Avatar
Default info please
Hey stew can you please tell.me everything that was used in this and your current setup? Parts and all mounting doesn't matter ill habde that just please list all parts and how you tuned it thank you much!
Old 01-27-15, 02:26 PM
  #167
Hoovey689
Hoovey689's Avatar
Any updates on 400whp with PPE?
Old 02-13-15, 05:02 PM
  #168
stewb10
stewb10's Avatar
The plans are changing everyday. This thread has everything I have so far already listed. For details check the classified ad.
Seeing is Believing: 358rwhp, 400rwtq Supercharged IS350 (DYNO'd)-image-664918832.jpg
Headers going on in the next couple weeks. And a LOT of custom machining to get this setup going in the next couple weeks as well.
Old 02-14-15, 07:19 PM
  #169
Gville350
Gville350's Avatar
Excited to see where this goes! Looking forward to your updates!
Old 02-14-15, 08:48 PM
  #170
Sylvan
Sylvan's Avatar
Interesting read, when getting pulleys machined due to belt slip why not go with a cog set up. I have never seen anyone use a boost limiting valve I suppose it makes sense because you would spin the blower up quicker in low rpm and then bleed boost higher in the revs similar to a waste gate I guess my concern would be the computer metering the air that you are bleeding off causing a rich condition. Is the drivability perfect? Just curious about flat spots or hesitations while driving.
Awesome project and thank you for sharing the trials and tribulations.
Old 02-15-15, 12:09 AM
  #171
stewb10
stewb10's Avatar
1) As far as the cogged setup, are you sure you read the thread?
2) The BLV is in the hot side piping, well before the MAF. Further, the only reason i'll need to back down the boost is a lean AFR. If I ran rich, I'd add in more boost until I wasn't running rich anymore, and titrate my water/meth mixture accordingly.
3) Yes. Drivability is like stock +100whp.
Old 02-15-15, 07:50 AM
  #172
ChickenIS
ChickenIS's Avatar
I missed this one. WOW
Old 02-20-15, 02:25 PM
  #173
stewb10
stewb10's Avatar
Headers installed now I get to rework my whole exhaust so it sounds good again...
Old 03-14-15, 11:54 PM
  #174
stewb10
stewb10's Avatar
Seeing is Believing: 358rwhp, 400rwtq Supercharged IS350 (DYNO'd)-image-1969389428.jpg
Standalone electronic boost control. Completely adjustable for opening pressure and duty cycle. AFR/PSI cutoffs. Boost MAF, wideband O2, and tach inputs. Data logging capability.
Wastegate
Colder plugs
Old 03-15-15, 12:23 AM
  #175
nikogio38
nikogio38's Avatar
Originally Posted by stewb10
Attachment 357317
Wastegate
Colder plugs
HOLYSHI!....IM JEALOUS YOUR GOING KILL THE WHP FOR IS350s....I give up. lol But on a side note I just purchased my LEXON EXCLUSIVE over fenders... im soon to be a boosted widebody running a 295 in the rear! haha
Old 03-15-15, 11:45 AM
  #176
Gville350
Gville350's Avatar
Colder plugs
Let me know the part number of those plugs if you don't mind. I'd like to run a step or two colder when I add nitrous and throw in some race-gas.com fuel concentrate.
Thanks!
Old 03-16-15, 06:05 PM
  #177
stewb10
stewb10's Avatar
HKS calls for 2 or 3 steps colder in the GT kit. I'm not EXTRA sold it needs more than one, but I may be using an oxidizing agent in the near future as well, so I went with 2 steps.
Denso IKH24
Old 03-16-15, 09:32 PM
  #178
codenko
codenko's Avatar
Did you end up pulling the front fenders to run 19x9.5?
Old 03-17-15, 12:04 PM
  #179
Gville350
Gville350's Avatar
Denso IKH24
Thanks man, much appreciated!
Old 03-17-15, 07:18 PM
  #180
stewb10
stewb10's Avatar
Any time!
Yes. But its more about offset that anything else. I'm running a 4" lip up there currently.
Quick Reply: Seeing is Believing: 358rwhp, 400rwtq Supercharged IS350 (DYNO'd)
