Seeing is Believing: 358rwhp, 400rwtq Supercharged IS350 (DYNO'd)
Old 03-24-15, 04:34 PM
  #181
stewb10
stewb10's Avatar
Seeing is Believing: 358rwhp, 400rwtq Supercharged IS350 (DYNO'd)-image-1568440986.jpg
First day went slower than I planned. Still a lot to do.
Electronics are done other than adding resistors to the tach signal and a boost line to the new controller.
Blower is back together as well. I'll get back at it Friday probably and hopefully finish it then.
Old 03-25-15, 06:54 PM
  #182
Gville350
Gville350's Avatar
Any fears that the auto trans won't hold-up over time at those power levels? I fear the trans being the weak link over the motor in the long-run.
Old 03-26-15, 08:06 AM
  #183
stewb10
stewb10's Avatar
I'm with you on that. My thoughts really revolve around the drivetrain as well, we've seen Stock bottom 2GR-FE's into the 600whp range. My guess is i won't know anything until i try to hook it at the track on some slicks/DRs.
The other thing to consider is that this is my daily and its slammed on bags. I'd say I go WOT about once or twice a month. I really love it for the added torque and mid-range. As long as i don't blow something up on the dyno, it should be fine.
Old 03-26-15, 11:46 AM
  #184
Nixcision
Nixcision's Avatar
sounds like you baby your car, which is a good thing.
The problem with the dyno and/or drag strip idea is that in itself could be the tipping point! In which case you won't have a dd for a while. Im sure you already know that tho haha
Old 03-26-15, 06:07 PM
  #185
Gville350
Gville350's Avatar
Yeah, with mine being the DD still I've delayed the nitrous install until I've got a secondary vehicle. But until then, I'll just have to be happy with my new, used PPE headers.
Old 04-10-15, 07:40 AM
  #186
stewb10
stewb10's Avatar
Well, she lives. Lots of little stuff to work out. Have a leak somewhere in my boost signal. Blowing off just fine, but boost gauge says zero. No wastegate or water/meth action either I'd assume. All off the same tree.
So, no numbers. Not even boost numbers
Old 04-10-15, 08:07 AM
  #187
dyongg
dyongg's Avatar
always been a fan of your car! all the time you spent on it really pays off man
Old 04-10-15, 01:10 PM
  #188
Gville350
Gville350's Avatar
IT'S ALIVE! Congrats man! Now onto figuring out the issues; aren't project cars the BEST? LOL!
Old 04-14-15, 10:51 PM
  #189
scott1256c
scott1256c's Avatar
So, I'm wondering, were (or are) you running around 50/50 water/meth? If not, what mix? Also how much water/meth to fuel were you running? I see recommended from about 10-15 percent.
Thx
Old 04-15-15, 11:53 AM
  #190
Low Life
Low Life's Avatar
Thx
I'm confused on how u are running mid 10 a/f. Also what is your duty cycle at? Also been patiently waiting for a 1/4mile trap speed :P
Old 04-15-15, 05:04 PM
  #191
scott1256c
scott1256c's Avatar
I don't know if you question was directed at me or not, but I was asking about the ratio of water/meth to FUEL not fuel to air. So 10% to 15% water/meth, 85%-90% fuel is the ratio I see used a lot. But I've seen some say you could go as high as 25%
Old 04-24-15, 05:40 PM
  #192
stewb10
stewb10's Avatar
This ECU is actually pretty good at adjusting. And my test/tune event each spring and fall is also my local show... So yea. I think it traps about -8.5* aired out. Lol. That's the beauty of a "closed course": 30-40mph roll negates any camber issues.
50/50 water/meth is a pretty standard ratio. Its the highest mix you can get that is non-flammable. Depending on applications, like on a high boost EVO, I'm sure you have to be more careful with it. Methanol will affect your tune.
Old 04-24-15, 11:06 PM
  #193
scott1256c
scott1256c's Avatar
50/50 answers the question of water to meth. I am also interested in how much (water/meth) to fuel you were using.
As in
I have read 10% water to fuel (if injecting water only)
Up to 25% water/meth to fuel (with 50/50 water/meth)
So I was wondering how much you were injecting, given that it sounds like you are using a 50/50 water/meth formula.
So have you found your leak? How is the boost controller/headers/cogged pulley working out?
Thx
Old 03-14-16, 12:34 PM
  #194
rlydeadly
rlydeadly's Avatar
As in
Thx
amazing build!
Old 03-14-16, 12:48 PM
  #195
metaleckz
metaleckz's Avatar
Imagine if rr-racing or ttfs tuned his car.
Quick Reply: Seeing is Believing: 358rwhp, 400rwtq Supercharged IS350 (DYNO'd)
