oem back up camera to flyaudio
Old 12-22-12, 12:39 PM
6lexis350
6lexis350's Avatar
Default oem back up camera to flyaudio
Does anybody know how to wire up a oem backup camera to the flyaudio? I tapped into the reverse camera to the wire labeled back on the flyaudio harness and put a video rca end on the camera wires and when i put it in reverse it says no video signal. Can somebody help me correct this? I appreciate it guys.
Old 12-22-12, 03:17 PM
bob4256
bob4256's Avatar
I would ask in the fly audio thread for some better responses.
Back when I had a FA unit, I bought a backup cam from eBay and wired it up to the unit and it worked
Old 12-22-12, 03:40 PM
06pearlex
06pearlex's Avatar
Everything looks like its was wired correctly ...Make sure there's power from the reverse wire the yellow video wire is connected correctly.
Old 04-19-14, 09:54 AM
monsterfa
monsterfa's Avatar
old post but I have the same problem. No Video Signal. Were you able to fix this problem?
Old 04-19-14, 10:51 AM
senxation
senxation's Avatar
The camera you buy should have a wire that connects to the back of the fly audio, and one that is required to be tapped into a 12V so that when you shift into reverse, the camera is able to turn on. Without the connection of the 12V, the signal from the head unit a lot will not power the camera. So be sure to connect that 12V to something such as your break lights, and be sure to ground the other wire that came with the camera as well.
Old 04-20-14, 05:33 PM
monsterfa
monsterfa's Avatar
I am actually trying to connect the oem backup camera since I installed the fly audio into my is that had factory nav buy the only things that don't work are the hazard buttons and the backup camera when I go into reverse it just shows no video signal.
lasem99
04-27-23 12:00 AM
Kasibona
RX - 3rd Gen (2010-2015)
06-27-17 07:39 AM
jaywish
09-26-13 07:04 AM
Quick Reply: oem back up camera to flyaudio
