Need help to install Passenger Mirror Glass
Guys,
busted my pass side mirror.
Just got a glass trying to install but kind of scared to push it too hard
Heard a lot of horror stories on how pips breaking glass while installing.
Any guidance on how to install it????
or
Anyone in Tampa area can help me, i would pay.
Thanx
Update:
Fixed it !!!
or
Thanx
Update:
Fixed it !!!
When I had a busted mirror, I just ordered the parts from Sewell and had the dealer do it. It was supposed to be $100-something, but ultimately was $200 because of some studs issue. I got a thread on it here: https://www.clublexus.com/forums/is-...sy-needed.html
Hook the top part in first.. then slide the bottom down. When applying force, spread your fingers out over the area just barely on the outside footprint of the clips.. applying directional pressure on those bottom sets of clips.
Don't be scared. It pops right in. You could try some light spray lube on the clips if you wanted..
Thaks
The main thing is not to spread your fingers out too much and press on the edges of the mirror as to make it flex and break. As long as your spreading out the force and not flexing it, you're fine.
Guys,
Thank you for all your input.
I GOT IT IN
One more thing i have to add,
do not "upwards" all the way, it help me to insert into TOP slots.
After that i snapped bottom clips, i think that grease i applied to clips helped a LOT.
Yeah, i'm happy camper
I GOT IT IN
Seems like an a little to late,I've could it help u.where in Tampa u @
Nphoops
08-28-18 07:26 AM
