Install Mesh Grill
Old 11-28-12, 11:02 PM
vicsis250
vicsis250's Avatar
Talking Install Mesh Grill
I have a 2008 IS250 and don't like chrome at all so I just bought this grill from ebay check it out. I'm thinking about blacking the chrome out to match the new grill.
http://www.ebay.com/itm/170852885569...84.m1439.l2649
My question is how do I go about installing it the easiest way please excuse the question for all you pro's out their. I'm used to working on car and I'm sure I would figure it out but I thought it would ask first. I don't want to break something that I will have to replace later. Has anyone ever installed this before and how? Pictures would be great.
Old 11-28-12, 11:38 PM
Hoovey689
Hoovey689's Avatar
to install the grill.. direction is as follows..
- pop the hood
- pull the rubber weather stripping off.. they are held down with a bunch of plastic plugs.. if the plugs come apart from the weather stripping its ok.. just take a pair of needle nose plyers pull them out of the hole on the car.. youll see little holes on the weather stripping.. stick one side of the T bar and strech the rubber until the other side goes in.
- unscrew the center hex bolt
- pop off any plastic screws u see holding down the grill.. to take the plastic screws out.. take ur fingernail and pull the center up.. then pull the whole screw out.
- slide out the chrome trim.. then slide out the grill..
- reverse the process to put it back together..
hope this helps
from is350jonny
Old 11-29-12, 06:52 AM
juvi22003
juvi22003's Avatar
Pretty good explanation from HOOVEY2411, I'm using the same grille but i removed the emblem. Pretty easy and straight forward installation
Old 11-29-12, 08:56 AM
BrandonIS
BrandonIS's Avatar
Is that the matching lower grille you have as well? Also, if I have a black pearl emblem, would I just lay that with the doubled sided tape on top of the L that this grille comes with?
Old 11-29-12, 09:02 AM
juvi22003
juvi22003's Avatar
The low grille is the stock / oem grille, the middle piece can be screwed out thats what i did and thats where the L goes. I hope i explained that correctly
Old 11-29-12, 09:07 AM
BrandonIS
BrandonIS's Avatar
Ahh, alright. I get what you're saying, thanks!
Old 11-29-12, 10:53 AM
Asher
Asher's Avatar
From the look on the ebay pic it dosnt have the mesh going under the L logo look again
Old 11-29-12, 01:46 PM
reyoasian
reyoasian's Avatar
What's that little thing that sticks out from both your bumper top edges to the fender?
More pics of your car? Looks good.
Old 11-29-12, 02:00 PM
vicsis250
vicsis250's Avatar
Originally Posted by Hoovey2411
from is350jonny
Thanks bro that is very helpful
Old 11-29-12, 04:18 PM
gucheese
gucheese's Avatar
Is there 2 separate ISF grilles, one that can have the emblem removed and the other you cant?
That's what it looks like from the eBay pictures
http://item.mobileweb.ebay.com/viewi...id=79237379388
http://item.mobileweb.ebay.com/viewi...d=170852885569
Old 11-30-12, 11:18 PM
Skrapp
Skrapp's Avatar
Is it difficult to remove the emblem from the holder? Will it come out clean/reusable?
Old 12-01-12, 05:41 AM
BrandonIS
BrandonIS's Avatar
I believe it might be possible, but it's probably best just to buy another off Ebay for $15 or whatever the price may be.
Old 12-02-12, 12:38 AM
vicsis250
vicsis250's Avatar
So I installed the new grill looks FN nice everything was reused included the Emblem just be careful and cut it out with a blade. I'll post some pic's soon
Old 12-03-12, 06:05 PM
juvi22003
juvi22003's Avatar
Bumper release tabs.
more pics here:
https://www.clublexus.com/forums/is-...-step-lip.html
Old 12-05-12, 06:26 PM
istarzan
istarzan's Avatar
Ordered the one in the first link. Seller said emblem holder is removable. Will update with pics.
Quick Reply: Install Mesh Grill
