Ok so I notice there a coolant leak under my car and I will replace the water pump
Anyrhing else I should change while I'm at it?
Also I the color of coolant is green.. Should I keep using this kind of coolant or replace it with the Toyota red coolant ? If I do will it make any issues?
Maybe previous owner replaced the water pump and used green coolant causing the gasket to leak?
Should I just change the gasket and used red coolant?
The water pump looks pretty new..
Anything else I should replace while I'm at it ?
Car is a 06 with 85k miles
While in there, change the belt and check the other pulleys for "play"...especially the alternator pulley. Those seem to have a known history for going out.
