What is your tire setup on 19" wheels
Old 10-17-12, 11:06 AM
IS250Slvr
IS250Slvr's Avatar
Default What is your tire setup on 19" wheels
Curious to know how big or small of tires people are using and if they have any rubbing issues. I just got some 19" but not sure how big or small of tires people are using???? Input would be greatly appreciated!!!
Thanks
Old 10-17-12, 12:37 PM
kumquatism
kumquatism's Avatar
Rubbing is highly dependent on your ride height and offset too. I run 215/35 on 19x9 and 235/35 on 19x10 and I still rub because my offsets are relatively low.
Old 10-17-12, 12:40 PM
GiantsFan
GiantsFan's Avatar
I'm running 235/35/19 Front and 265/30/19 Rear.
My offsets are +30 front and +35 rear (my new wheels will have +33rear)
No rubbing. No issues.
Old 10-17-12, 12:47 PM
projectdna
projectdna's Avatar
Thanks
two factors determine what tire sizes you should be running to get the most clearance.
1. wheel specs - more specifically, width and offset
2. ride height
having said that, try using the search function for something that has been covered many, many times.
hope this helps.
Old 10-17-12, 12:59 PM
01ES300NYC
01ES300NYC's Avatar
stock ride height (sport pkg susp.)
f: 19x 8.5 38et 235/35/19
r: 19x 9.5 38et 255/35/19
zero rubbing issues!
Old 10-17-12, 01:01 PM
600rr05
600rr05's Avatar
pretty much what projectdna said all depends on size. my offset is really Conservative +37 all around before i had the cup kit tucking a little tire the front would rub on turns and rear just depends on bumps in the road. tire size im running is 225/35/19 & 265/30/19
Old 10-17-12, 01:26 PM
juvi22003
juvi22003's Avatar
215 35 and 245 35 on my 19x9.5+22 and 19x10.5+22
225 35 and 245 35 on my 19x9.5+24 and 19x10.5+24
What is the width and offset of your wheels?
Old 10-17-12, 01:52 PM
RDIS250AWD
RDIS250AWD's Avatar
I run 19s in the winter
19x8.5 f and 19.9.5 r
235/35/19
275/30/19
Old 10-17-12, 02:18 PM
IS250Slvr
IS250Slvr's Avatar
235/35/19
275/30/19
Your car looks lowered, how much of a drop did you do??
Old 10-17-12, 02:46 PM
RDIS250AWD
RDIS250AWD's Avatar
yes its dropped on Megan springs 1.25
Old 10-17-12, 04:39 PM
HeartmyIS
HeartmyIS's Avatar
im lowered about 3.5" and im running 19" with 225/35 and 265/30
Old 10-17-12, 05:55 PM
rookieIS
rookieIS's Avatar
19x9.5 + 37 - 235/35/19
19x10 + 32 - 265/30/19
Old 10-17-12, 08:51 PM
chase350
chase350's Avatar
19x9 +12 with 215/35/19
19x11+20 with 245/35/19
Old 10-17-12, 08:55 PM
chase350
chase350's Avatar
Roll hard or don't roll at all lol
Old 07-03-15, 02:19 PM
jodc1012
jodc1012's Avatar
Trying to determine what tire size to get. Hope you all can help with suggestions.
Weds kranze lxz
Front 19X9 35 offset
rear 19X10 31 offset.
Thanks
Quick Reply: What is your tire setup on 19" wheels
