Brake pedal vibration
Old 10-06-12, 05:09 PM
JDMis350
JDMis350's Avatar
Default Brake pedal vibration
I jus changed my front brakes and had my rotors resurfaced because they were glazed and started sqealing every time I use the brakes. Now the squealing is gone and brakes work fine except there's a Vibration in the brake pedal that carries all the way up to the steering wheel when coming to a stop from 60 mph, I was in the process of bedding my pads and rotors when it started happening ..anyone have any idea what causes this or has this happened to Anyone that has changed there brakes themselves before ? This is the first time it's happened to me. Any Input would b appreciated thank you
Old 10-06-12, 07:06 PM
ibidu1
ibidu1's Avatar
weird possibly the rotors got warped, you may want to take them off again and take them to check straightness again. Or buy new rotors, aftermarket rotors are fairly cheap
Old 10-06-12, 07:07 PM
Sffd103
Fire Slayer
Sffd103's Avatar
Sounds like the rotors are warped......take it back if you had it done at a shop.
Old 10-06-12, 10:02 PM
Kurtz
Kurtz's Avatar
Rotors don't warp if they're installed correctly... (course with the timing in this case, perhaps they weren't)
Pedal vibration that's usually mis-diagnosed as warped rotors is uneven pad transfer but if you do a proper bed in, which you said you were doing at the time, you avoid that issue-
http://www.stoptech.com/technical-su...nd-other-myths
Old 10-07-12, 05:01 AM
slimjimtel
slimjimtel's Avatar
Does it do it all the time, or only when you hard brake from 60 to 0?
If you're hard braking and it does it, it's your ABS kicking in, which will give you a pulsing brake.
If it does it all the time under regular light braking, then most likely one of the rotors are are warped.
Old 10-07-12, 12:54 PM
diagtime
diagtime's Avatar
whoever machined the rotors screwed up. happens all the time.
flyboyplo
08-27-13 05:58 PM
jeff1941
Wheels, Tires & Brakes Forum
01-28-08 04:31 PM
Shawnmack
RX - 1st Gen (1999-2003)
19
09-11-07 12:24 PM
DaJark
Suspension and Brakes
10-16-06 06:16 PM
studaddy
10-11-01 01:14 PM
Quick Reply: Brake pedal vibration
