car shaking between 75-85 MPH!!
Old 10-03-12, 05:50 AM
abitta1
abitta1's Avatar
Default car shaking between 75-85 MPH!!
hey guys. My car been shaking when i drive between 75-85 mph only.. once i pass 85 it doesn't shake anymore. my question is what do you guys think its causing this problem?
Old 10-03-12, 05:53 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Start with the easiest, have the tires balanced... it is perfectly normal for them to only shake at a certain speed. While they are being balanced, have them inspect the tires for any other potential issues...
I would say in the grand scheme of things, there is a 95% chance that is all it is... Other potentials include ball joints, control arm bushings, etc. Lets not go there until we have eliminated the most likely...
Old 10-03-12, 06:03 AM
abitta1
abitta1's Avatar
I was hoping that would just be the issue. I will do that this weekend and let you know. Thanks
Old 10-03-12, 06:05 AM
jbjones85
jbjones85's Avatar
I had the same issue between 78-82 on mine. Got the tires re-balanced and no more issues.
Old 10-03-12, 06:06 AM
ms2619
ms2619's Avatar
same^^ I upgraded to 19's and it shook at 80-85 once i got them rebalanced not one shake afterwards
Old 10-03-12, 06:24 AM
abitta1
abitta1's Avatar
niceee!!! now im getting less stressed about this issue. I thought it was gonna be something big.. Thanks guys
Old 10-03-12, 11:25 AM
Gville350
Gville350's Avatar
Sorry to throw a wrench into the works, but it can also be a bent wheel. I had a similar steering wheel shake from 70-80, and it ended up being a bent driver's side rear wheel.
GL!
Old 10-03-12, 12:19 PM
jbjones85
jbjones85's Avatar
This is also possible but when he takes the wheels/tires to be balanced they should be able to let him know if they can't be balanced and its something more major.
GL!
Old 10-03-12, 01:02 PM
Gville350
Gville350's Avatar
^Well, a GOOD shop will tell you the wheel is damaged/bent...BUT will try to balance it out (if possible) anyways. I had Discount Tire do that to my bent wheel until I could procure a good used one (purchased on CL BTW ).
Old 10-03-12, 01:59 PM
Sango
Sango's Avatar
Are these brand new tires? It could be the one or more of the new tires is not true, as in the tire is not in spec (as in oval as opposed to round), which can make it do this at high speeds and should be replaced right away as its a defect.
Another could be the wheel bearing is worn out, therefore the wheel hub assembly would need to be replaced.
ronnymo
ES - 5th Gen (2007-2012)
09-20-15 12:35 PM
fmLexus
04-29-12 09:10 AM
jasonlee
Suspension and Brakes
01-26-09 12:47 PM
Lexis11
30
08-25-05 12:44 PM
Quick Reply: car shaking between 75-85 MPH!!
