Short Shifter
Old 09-28-12, 06:46 AM
AussieAuto
AussieAuto's Avatar
Default Short Shifter
Installed a genuine short shifter on an IS250 last week. Quite an easy install if you have a hoist,
just undid tailpipe section from mid pipe at swivel (so no gasket replacement needed), then undo and drop trans cross member, now shift mechanism is accessible. remove existing boot cover, remove c-clip and take out shift lever from selector rod, slide off old boot and slide on new one. install short shifter to shift lever, it says to apply Toyota fipg to either side of s/shifter so it bolts together and stays sealed, I have FIPG which I used but any silicone sealer will do, and then attach to selector rod, re install c-clip and then what I found to be the hardest part of the job slide new boot cover over mechanism and secure by pulling up over all to sit tight up against aluminum mount. Refit cross member and two exhaust bolts with springs. Hope this helps for anyone wondering how...
HTML Code:
[ATTACH]259363[/ATTACH]
[ATTACH]259364[/ATTACH]
[ATTACH]259365[/ATTACH]
[ATTACH]259366[/ATTACH]
Attached Thumbnails Short Shifter-mississauga-20120917-00149.jpg   Short Shifter-mississauga-20120917-00153.jpg   Short Shifter-mississauga-20120917-00155.jpg   Short Shifter-mississauga-20120917-00157.jpg
djlookup (12-14-19)
Old 09-28-12, 08:18 AM
Sffd103
Fire Slayer
Sffd103's Avatar
I always wondered what it looked like installed. Can't believe I paid to have this installed at the dealer. Oh well.
Old 09-28-12, 09:12 AM
cyberscorp
cyberscorp's Avatar
I was gonna do a "How To" on this project but this post is Perfect Timing (when I install mine in a few weeks) !
Old 10-01-12, 07:05 AM
AussieAuto
AussieAuto's Avatar
Glad to help, good luck with your install, I forgot to mention to undo the exhaust heat shield and slide it towards the rear to make access easier, it has sharp edges too...
Old 10-01-12, 08:06 AM
cyberscorp
cyberscorp's Avatar
Thanks for the Tip Bro.
Old 10-01-12, 11:12 AM
isam250
isam250's Avatar
tell me how long it takes for you to get used to the short shifter. it was fun and felt different for a week for me. now it just feels whatevers
Old 10-01-12, 12:03 PM
kickin8
2IS/2RX/4RX
kickin8's Avatar
A MUST HAVE item!
Old 09-11-16, 12:18 AM
JohnMorgan
JohnMorgan's Avatar
Sorry to bring up an old thread but seeing that there are no more short shifters out there I'm going to have to design one myself or work with someone to make one.
Does the F sport shifter "Cover" and extend the oem shifter or does it replace the bottom half portion of the shift lever?
From what I can tell it covers the oem bottom portion and makes a new connection an inch lower for the shift linkage. Any help would be appreciated!
Old 09-11-16, 09:39 AM
JohnMorgan
JohnMorgan's Avatar
Originally Posted by Allan1
There are still some places that sell it about 200 USD range. But for me, the price with shipping and taxes would be ca 500 USD, not worth it.
Do you know who still sells it? It's been a wild goose chase looking for one. I had my friend at Lexus look it up and the last one in the system sold in San Deigo the day I was looking haha.
Old 09-13-16, 09:37 PM
topspeed55
topspeed55's Avatar
It just covers over the existing. A good CNC guy can replicate this, let us know if you can get one made and I'd be interested in a group buy.
Old 09-14-16, 01:35 PM
JohnMorgan
JohnMorgan's Avatar
will keep you posted. Taking measurements on an extra transmission I bought and then I'll do some 2D drawings, just have to find someone to convert to 3D, 3D print a prototype and then boom. Or just give all the info to FIGS and let him handle it haha.
Old 09-14-16, 03:52 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
It extends the shifter approx. 25mm. In case you were wondering.
It seems the boot may actually be the harder part to source.
Jeff
Old 09-14-16, 04:28 PM
JohnMorgan
JohnMorgan's Avatar
Thank you so much for the information Jeff!
Jeff
Old 09-18-16, 06:40 AM
sashax415
sashax415's Avatar
Nice work. I really wish they would have made a manual IS350.
JesLet
Performance & Maintenance
96
08-17-19 11:37 PM
RichKeagy
07-26-19 05:37 AM
2GSC300
05-14-13 09:53 AM
mitsuguy
SC- 1st Gen (1992-2000)
48
08-18-07 09:21 AM
Quick Reply: Short Shifter
