Proper DIY tire rotation??
Old 09-24-12, 07:09 PM
maniacbob
maniacbob's Avatar
Default Proper DIY tire rotation??
Hey guys,
I want my tires to tread evenly. What do you think is the proper way to do a tire rotation for the AWD is250?
I'm thinking:
Cross the Front tires left to right on the way to rear.
Rear tires stay on same side moving to the front.
Thoughts? Thanks in advance!
Old 09-24-12, 07:49 PM
WERK
WERK's Avatar
Flipping your tires from left to right would be more effective.
Old 09-24-12, 07:54 PM
evogt500
evogt500's Avatar
Check to see if the tire are directional. Swapping directional tires from left to right will not help.
Old 09-24-12, 08:06 PM
nahrah
nahrah's Avatar
I have directional on my awd, so I did front to rear and rear to front.
Old 09-25-12, 09:31 AM
zen
zen's Avatar
According to my SA at dealership, they never crossed rotate. it's only from front to rear or rear to front.
Old 09-25-12, 09:54 AM
reyoasian
reyoasian's Avatar
Depends on tires like most said
If it's directional then only do front/rear
Old 09-25-12, 11:03 AM
sutekidane
sutekidane's Avatar
I always wondered how this is done, since the rear tires are significantly wider than the front. It wouldn't make sense to swap front/rear on the same side right? Should the tires be non-directional, it can be swapped left/right correct? Thanks
Old 09-25-12, 12:03 PM
evogt500
evogt500's Avatar
OEM AWD models have the same tire dimensions front and rear. RWD models have wider rear tires. If you have RWD model with directional tires, tire rotation is not possible.
If you have AWD model with directional tires, only front to rear rotation is possible.
If you have AWD model with non-directional tires, left to right and front to rear rotation is possible.
Do they even sell non-directional low profile tires?
Old 09-25-12, 12:05 PM
Hoac
Hoac's Avatar
^If they do let me know! Wish I could swap my tires from one side to the other and balance out the camber wear =o
Old 09-25-12, 01:26 PM
knguyenk
knguyenk's Avatar
I was taught by my automotive mechanic teachers that for AWD, you can only rotate them front to back, just like zen said.
For RWD or FWD is the front wheels go straight to the back and the backs come to the front but inverted (right is on the left, vice versa).
And depends on directional tires like what evogt500 mentioned too.
Old 09-25-12, 02:09 PM
KillaIS250
KillaIS250's Avatar
Most RWD set ups are staggered from the factory now so that's not really true for RWD cars. You can only swap tires left and right on the same axle for staggered tire set ups.
Old 10-01-12, 03:42 PM
knguyenk
knguyenk's Avatar
Ah, true that. The staggered setup completely slipped my mind.
Old 10-01-12, 04:26 PM
Sango
Sango's Avatar
Yup, at one point in time, they were the the same but now it's staggered.
As per cross-rotation, even if it was directional or not for RWD, it would be up to the discretion of the tire tech of it's feasible and able to be crossed/flipped depending on the tire.
kahuna415
RX - 3rd Gen (2010-2015)
07-24-14 07:07 AM
bowenn13
06-24-12 08:30 PM
LIMS407
Wheels, Tires & Brakes Forum
09-16-10 09:39 AM
K-Bud
GX - 1st Gen (2004-2009)
02-18-08 06:24 AM
Quick Reply: Proper DIY tire rotation??
