IS250 Carbon Build up CSP
#901
Just purcahsed 2007 IS250 from Lexus of Carlsbad 3 months ago car is awesome fully love it! Few weeks ago car srated showing signs of carbon build up issues!!! I have been fully stressed about this so I contacted Lexus corporate they had no idea what i was talking about, called lexus carsbad they were even worst telling me its my "idle control spring" I told them are you guys idiots or what? So all day yesterday I have contacted Lexus several Lexus in SOCAL and there all telling me i have to pay the $139 for the inspection fee. This situaion sucks because this is the last thing we should all be worried about owning a LEXUS!
#902
I wish it were that easy for me. In Canada the issue is not as widespread and has not been reported as much, so no such TSB has been registered. Which means that if I get the carbon build-up issue, I have to pay out of pocket to get it fixed. It's garbage.
#905
Hello all. First post here. I apologize as I'm sure these questions have been asked, but I recently discovered this board and not sure I'm up for searching through 60+ pages of posts on the subject. I have the rough idle issue, but unfortunately have not been able to get it fixed, so I'm wondering if I have any course of action.
The issue first started in December of 2011. What happened was, I was making a turn at a light, hit the gas to accelerate and the engine started to rumble and sputter, the check engine light came on, and the display showed "Check VSC"(or something like that), and I couldn't go faster than about 30 mph. Got the care home and shut it off, made an appointment at my Lexus dealership for the next day. The next day I brought it in and it ran fine. They did some diagnostics and said something about carbon buildup in the engine that they cleaned out, and added something to my gas tank.
The second time was in December of 2012, and pretty much the exact same symptoms occurred. I shut the car off for a few minutes, restarted it, and drove straight to the dealership. This was not long before the CSP came out about the rough idle issue. I got the letter a week or two after the dealership again checked it out, and called my dealership to ask them about it. They claimed they were doing the testing for the issue, trying to reproduce it. But I was told that since they could not reproduce the issue there, they would not be authorized by Lexus to do the repairs.
Before December of 2011, I had definitely noticed the rough idle when coming to a stop now and then. I have noticed it since then as well. Not often, but it does happen.
I kept thinking I would see the issue again, and the dealership would be able to reproduce it, but that has never happened. However, I have also been reading stuff on here and elsewhere that the reproducing thing isn't necessarily true, and if I have enough of the misfire codes, the dealership should do the repair. So, I have a few questions.
1. Will the misfire codes from the last several years still show up when a tech looks at the vehicle?
2. Should this be enough for the dealership to do the repairs?
3. My dealership is Lexus of Wayzata (Minnesota). Has anyone had this issue repaired there?
4. Is it worth it to find another dealership somewhat nearby to take it to if they have fixed the issue by just finding the misfire codes in the diagnostics?
Thanks in advance for any help.
#906
#907
Boosted, I highly suggest you take a drive up north to lexus of Cerritos and tell them your car feels sluggish and bogs down once in a while. You can even ask for Debbie C. She was my service advisor. She'll know right away about the problem. We just bought a used is250 one week prior and I started to read up on this website and found the carbon problem. I called Cerritos lexus and told them I just bought a one week old used car with 60k on the ODO and asked if they knew about a carbon buildup issue. She said they would provide me a loaner and thoroughly go over the car including the engine. I was in a loaner for 3 days when they called back saying the engine did indeed misfire and it would be covered under the lexus CSP campaign. 3 days later I get my car (wifes car) back and all is well and im told the engine is actually covered for 9 years unlimited mileage for this issue from the original date of purchase. So basically my engine is covered for at least another 4 years. Way to go Lexus!
#908
Still putting off having mine done, even though I've already been approved. Want to hear more evidence from people that it actually fixes the rpm problem and doesn't create other problems like lower mpg's, less power, etc...
#909
From my experience, the repairs has helped with the rpm issue. The car is more responsive from a stop and I haven't experienced the rough idles/bogging issues. The one downfall I have been experiencing is lower mpg's. Nothing too drastic, but noticeable (25 to 24). I had my repair done a month ago.
#910
The TSB's reference number is L-SB-0068-11. Ask them to look that up and print it out, and if your car is exhibiting the symptoms, they can run tests to see if they can re-create the symptoms. If they can, you should be covered.
#915
