how to check if water pump going bad?
Old 09-14-12, 11:14 PM
Shervin350
Shervin350's Avatar
Default how to check if water pump going bad?
so many water pump issues want to see how i can figure out if mine is going bad, by the way where is the water pump located so i could check for pink coolant
Old 09-14-12, 11:26 PM
aznoutkast
aznoutkast's Avatar
dang seeing this brought up so many times as well...glad you made a thread..hopefully a fellow cl will adress this issue
Old 09-14-12, 11:35 PM
tedward88
tedward88's Avatar
Fill up the coolant up to full line. Run the car for a while, check if its still on the full line, if not refill again. Once in a while check the coolant fluid level, if the fluid is slowly going down, the water pump may possible have a small leak or is getting ready to go.
Old 09-14-12, 11:37 PM
Shervin350
Shervin350's Avatar
i see in some place they show pink coolant around water pump but where is the water pump located?
Old 09-14-12, 11:45 PM
es808
es808's Avatar
From the Sewell Lexus website:
http://is.sewellparts.com/oem-catalo...S350-2009.html
It's the one labeled WP. The serpentine belt should be at the front of the engine, right behind the radiator. It should be about mid height on the engine on the passenger side. Look for the pulley wheels and it should be easy to find.
Old 09-15-12, 06:19 AM
greg0126
greg0126's Avatar
Just monitor the coolant level. That's how I found out mine was leaking.
Old 09-15-12, 07:45 AM
chase350
chase350's Avatar
Water will be leaking form the pump.
SharpGent
02-19-19 06:49 AM
Lexus081
ES - 5th Gen (2007-2012)
17
12-29-16 09:12 AM
916gs400
IS F (2008-2014)
07-28-15 12:13 AM
xxtoobsxx
Performance & Maintenance
04-17-08 08:26 AM
jasonnich
07-11-02 06:47 AM
Quick Reply: how to check if water pump going bad?
