How to remove IS350 2009 Passenger Side door panel?
Old 09-13-12, 03:49 PM
namhoang22
namhoang22's Avatar
Default How to remove IS350 2009 Passenger Side door panel?
Hello All,
Someone broke my side mirror and I tried to install a new one. I read online and people saying that I need to remove the door panel to install the new side mirror. I had been searching around and I found some suggestion I did follow those instructions but I still can't get the panel off because it was so tight. I tried to pull it off but I afraid I may break the panel. some of the instruction is for earlier model so I don't know if that will work with my 2009 model or not. Can some one please help me or give me some pictures on how to get this door panel off?
I have done these thing like the picture in this links show but I can't get the panel off
https://www.clublexus.com/forums/is-...-pictures.html
Thanks you so much for your guys help.
Old 09-13-12, 04:03 PM
UtoyZ
UtoyZ's Avatar
everything should be the same for all ISx50. once you remove the 2 screws, the panel is held by clips, a lot of clips, i'd say about 7 that's why it's hard to remove. just pull starting from the bottom, but dont pull too far out since there will be some wires that are attached. once you removed all the clips, you gotta slide the panel kinda upwards. oh and make sure the window is rolled down
woolwichgb
12-09-17 08:36 AM
elsmooth
10-03-14 05:13 PM
JohnAMG
GX - 1st Gen (2004-2009)
10-30-05 07:41 AM
chrislee8
04-10-01 07:44 AM
Quick Reply: How to remove IS350 2009 Passenger Side door panel?
