Seafoam Treatment
#32
I loosened up the MAF sensor between the air filter box and the throttle body. You can't remove the sensor. But you can lift it up and insert the thin plastic nozzle.
When you spray the fluid. The car starts to stall at idle. So I had someone hold the accelerator and rev the engine.
#34
I did use in the tank to start with and now I switched to Lucas in the tank every 3 months:
http://www.lucasoil.ca/products/prod...&cat=HeavyDuty
Hard to say what it does because the Seafoam treatment made a clear difference, but it's peace of mind.
#35
