HELP!! Check VSC code
Old 08-19-12, 11:56 AM
dci4life
dci4life's Avatar
Default HELP!! Check VSC code
Car is reading a wierd code. What does this mean and how do I fix it??
Old 08-19-12, 12:01 PM
Gville350
Gville350's Avatar
Did you get that msg / CEL at start-up or during normal operation at temperature?
Old 08-19-12, 12:37 PM
ibidu1
ibidu1's Avatar
I would clear it and see if it pops up again
Old 08-19-12, 03:19 PM
dci4life
dci4life's Avatar
Yeah It happened at start up. Immediately drove to an auto zone and had them check it. If my memory serves me right I had it cleared and waited for it pop back up again about 3-4 months ago and it just came back today. But I ended up driving with it on and traveling roughly 200 miles and I turned the car off then back on and it was gone. Does anybody know what it could be? I just don't want it to be a bad thing if I don't get it fixed.
Old 08-19-12, 07:06 PM
Gville350
Gville350's Avatar
Have you ever or do you currently get the start-up grinding noise upon start-up? Have you had this TSIB performed on your car?
Old 08-19-12, 08:28 PM
dci4life
dci4life's Avatar
What is TSIB?
Old 08-20-12, 12:06 AM
tedward88
tedward88's Avatar
http://www.obd-codes.com/p0014
Old 08-20-12, 12:21 AM
ibidu1
ibidu1's Avatar
Sounds like the symptoms of Carbon build up. Is this an IS250?
Old 08-20-12, 07:23 AM
dci4life
dci4life's Avatar
Thanks peeps you have all been valued help. I appreciate it.
Old 08-20-12, 11:55 AM
Gville350
Gville350's Avatar
After reading that link, it surely sounds like the symptoms of the carbon build-up TSIB.
Yes, AWD IS250 according to his garage.
mvrod
10-03-18 02:24 PM
Joppa013
10-27-17 12:44 PM
is250pr
01-12-17 07:24 AM
azncapcom
ES - 5th Gen (2007-2012)
02-24-16 12:24 PM
Quick Reply: HELP!! Check VSC code
