Rim Width! Will it fit?
Old 08-14-12, 05:23 AM
Barker
Barker's Avatar
Default Rim Width! Will it fit?
i am looking at a set of AME fins, 19x9.5 et-22 and 19x11 et-10. Will they work, i know arch work will be needed but who runs wide wheels on stock arches? whats the limits?
car has zeal function x coilovers
Old 08-14-12, 06:52 AM
Sffd103
Fire Slayer
Sffd103's Avatar
If you want to flare the rear quarter panels they'll work. Nobody with an IS has a - offset. The front will need a roll and pull too. I wouldn't force it.
Old 08-14-12, 07:09 AM
Barker
Barker's Avatar
suppose there is only one way to find out really, buy them and adjust to fit!
was just checking if anyone has done a similar spec.
Old 08-14-12, 07:10 AM
RDIS250AWD
RDIS250AWD's Avatar
Without any modding the max that'll fit in the front is a 8" wheel. I have a 19x8.5 in front now and there's a slight rub when I turn. As for the rear I was told the max is 10". I have a 19x9.5 now and the wheels I have coming next week are 20x10 in the rear so ill let u know how that feels once I get it on. But as Mariono said you'll need to flare those quarters. Nmpeter is the only member I've seen done it https://www.clublexus.com/forums/sho...d.php?t=595208
Old 08-14-12, 07:21 AM
laobo979
laobo979's Avatar
You can run a 9.5 width and not rub so 8 isn't a max.. It's more of the offset. There are member who ran 11.5 rear with high offset without fender mods again offset play a role. For the OP so with the 11 width you need camber in the rear, roll and a good pull. I run a 9.5+16 up front all was needed is a roll, pull, and tab relocated.
Old 08-15-12, 12:55 AM
Barker
Barker's Avatar
i'll check it out!
Old 08-15-12, 04:05 AM
o7iS250
o7iS250's Avatar
I'm running a 19x9.5+19 in the front and 19x11+22 in the rear and I have the fronts rolled and a slight pull, and the rears rolled and with pretty decent pull getting done right now.. I'm anxious to see you pull this off! Anything can fit on ANY car with the right modification.. and lots of money of course lol
Old 08-15-12, 05:19 AM
Barker
Barker's Avatar
i lack the money part but i have the stupidity to try it haha
Old 08-15-12, 07:35 AM
projectdna
projectdna's Avatar
you'll find that it won't be so funny when you get halfway there and realize that (one way or another) it's actually going to cost you money.
and there's a little saying that goes like this:
"if you want to play, you'll have to pay."
Old 08-15-12, 09:49 AM
Barker
Barker's Avatar
I did the same with my golf tbh
Old 08-15-12, 09:57 AM
projectdna
projectdna's Avatar
you can do whatever you want, go for it.
but just because you did it with your golf doesn't mean the same applies for the 2is.
btw, are you sure those proposed wheel specs have negative or positive offset?
reason being, if it's positive offset, you can still make them work (albeit barely). if it's negative offset, forget about it.
Old 08-15-12, 10:10 AM
laobo979
laobo979's Avatar
I think it's just et dash 11. I hope he didn't mean negative 11 cause then your looking at major body work.
Old 08-16-12, 02:42 AM
Barker
Barker's Avatar
yeh sorry just dash, its +11
and i'm not saying because i done it with the golf it will work on the golf, i'm saying i done the fit it before asking what would work and i really dont want to have to spend a fortune on arches and arch repair work but i still want wide wheels but as you said "if you want to play, you have to pay"
AJU72
07-06-17 05:37 PM
LEX1989
IS - 1st Gen (2001-2005)
03-21-11 03:49 AM
bigjez
03-30-09 12:25 AM
MrMark
07-27-06 10:09 AM
Quick Reply: Rim Width! Will it fit?
