low oil pressure vs level
Old 08-11-12, 10:08 AM
edgeucated
edgeucated's Avatar
Default low oil pressure vs level
This is a noob question, but is the "low oil pressure" message the same thing as a low oil level?
I'm asking because yesterday I had to do a panic stop and the "low oil pressure" flashed for a second and then turned off. When I got home, I checked my oil level and it was a little low, so I added in .5 of a quart. Im just about due for an oil change and my car has never had any oil problems before.
Am I looking at a bad oil pump or was I just slightly low on oil?
Old 08-11-12, 10:20 AM
rocks
rocks's Avatar
If the light has not returned then yes it was your low oil level that prompted it. That's how it works on my bimmer. If the oil level was fine and the light stayed on then it would mean the oil level sender/sensor is defective and needs replacing.
Old 08-11-12, 10:26 AM
es808
es808's Avatar
Typically it's the same when you have a low oil level. With the lower amount of oil, it will slosh around in the pan when you brake or turn. This may starve the oil pickup for a second and thus oil pressure will decrease briefly as well. The sensor will detect this low pressure and flash the light on your dash. Same as you experienced....
It shouldn't be a problem unless you're burning oil or getting the warning light under normal driving conditions.
Old 08-11-12, 11:29 AM
Gville350
Gville350's Avatar
Curious, where is the oil sending unit on a 2IS? Is the unit's reading pre or post oil pump through the galleys?
Old 08-12-12, 10:58 PM
diagtime
diagtime's Avatar
Post, It's on top of the oil filter housing. single wire coming from the passenger side of engine down to oil filter area. It's rare, but the pin on that connector has been messed up before from engine work. most people doing engine work on that engine will swing entire wiring harness (including pressure sensor wire) to driver's side of vehicle. .5 quarts low shouldn't cause either light.. If your car has even a half decent oil change history, i wouldn't worry about it. May never see it again. If you do, let us know.
firestart9 (11-27-22)
Old 11-27-22, 09:26 PM
firestart9
firestart9's Avatar
ttt for anyone with more experience/stories. Got low engine oil light today.
Old 11-28-22, 06:45 AM
2013FSport
2013FSport's Avatar
Received 1,484 Likes on 1,238 Posts
What's up? Does it leak or burn oil? Oil consumption can be masked by cats burning it minimizing the typical blue haze.
If its full and the low level light is still on, check the connector on the right side of the oil pan.
Aus430
10-10-18 08:37 PM
Ken167
11-29-17 12:48 PM
KSwag0525
07-27-17 01:53 PM
Conant
Maintenance
03-25-17 07:14 AM
Jackal
01-01-07 04:25 PM
Quick Reply: low oil pressure vs level
