OEM staggered setup? WTF?
So I buy all my tires from America's Tire cause they always give me the best deals. I recently got the car and didn't think to really check the tires cause It didn't even cross my mind that it would be a staggered.
So last weekend when they pulled the tires off I realized the front tires were flush with the rim while the rear ones were hanging over a little. I checked the back of all the wheels and sure enough they are all 17 x 8
2 questions.
Why would they do this?
and
Could I swap out the front tires for wider tires as well so I could do a rotation. I've never liked staggered setups because you can't rotate.....
2 questions.
and
If have an AWD 250, then that is a problem. If you are RWD, then that can be done. But if Americas Tire Co did it without your knowledge, that would be interesting because the wider tires are more expensive. The only problem it will cause is the afore mentioned tire rotation issue.
Keeping it Real
Stock is 17x8 all around with 225 front/245 rear. It's what the car is supposed to have.
You can switch to a square setup if you'd like without issue, but what they installed is correct (unless you have AWD).
I am running 245/40R17 all around on my RWD with the stock 17x8 wheels.
Jeff
Jeff
Jeff
Jeff
