55w hid in fogs?
Old 08-03-12, 05:18 PM
mililani00
mililani00's Avatar
Default 55w hid in fogs?
can i run 55w hid on my fogs ? thanks
Old 08-04-12, 03:51 PM
aznlonly
aznlonly's Avatar
you can, but just make sure you use a relay.
Old 08-04-12, 05:27 PM
GQis350
GQis350's Avatar
What color you going with
Old 08-04-12, 05:39 PM
Vroomin350
Vroomin350's Avatar
Why is the real question?
Not only will you risk MELTING the foglight housing, but fogs typically have less than great deflectors and a 55W HID in there is just gonna overpower your headlights, especially if you have projectors on the headlights.
Old 08-04-12, 06:15 PM
minato
minato's Avatar
are you saying this is bad?
i been running HID on me car for a while with a relay and havent had any problems..
Old 08-04-12, 07:14 PM
Sango
Sango's Avatar
Are you using a 35 W HID?
He's referring about a 55 W HID as opposed to a 35W.
55 W does use a lot more power and there have been reliability issues, not to mention the bulb would naturally have a shorter life span. Also question about legality as well.
Old 08-04-12, 11:01 PM
mililani00
mililani00's Avatar
i want to go with 3k. i dont want to put the yellow vinyl. i ask 5 or more companys and they said the 3k is greenish yellow. i want golden yellow so maybe higher watts mean more true color will come out.
Old 08-05-12, 03:07 AM
KillaIS250
KillaIS250's Avatar
The wattage won't really make a difference in color.
I wouldn't personally run 55W in the fogs myself, its too much light in a small reflector space so it will just be a lot of glare for others. Plus, there's always the risk of melting the housing.
If it helps, my 3k kit from DDM Tuning on my Prelude was a golden yellow. No green at all
Old 08-05-12, 01:58 PM
mililani00
mililani00's Avatar
killaIS250-hmmm ill look in to that, thanks bru!
Old 08-06-12, 05:34 AM
aspeckt
aspeckt's Avatar
what wattage is good for the fogs then? i already have ballasts in there, and looking to buy new 10k ones. i currently have 8k but i think one burnt out. any suggestions?
Old 08-06-12, 09:18 AM
Sango
Sango's Avatar
35W is all you need. Are you using 10K as more of a show car? The kind of color is kind of going to ask for a ticket.
Old 08-06-12, 10:12 AM
KillaIS250
KillaIS250's Avatar
Avoid 10k. Like Sango mentioned, you're just asking to get pulled over if you are running 10k lights
Old 08-06-12, 11:11 AM
minato
minato's Avatar
I have to take them out then, cuz i have been running 55w HID's for some time now
Old 08-06-12, 11:36 AM
Sango
Sango's Avatar
Sounds like you have to change both if your bulb and ballast is both 55w. About the legality part, it's as in too bright and could be considered blinding to other drivers.
It's also one reason why most places which sell hid kits mainly would sell 35w over a 55w.
Old 08-06-12, 01:16 PM
aspeckt
aspeckt's Avatar
ok. i was running 8k originally, i guess i will just stick with that
Quick Reply: 55w hid in fogs?
