Old 01-06-15, 05:08 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior Guides
Print Wikipost
Installing a new windshield myself
Old 08-12-14, 11:47 PM
  #46
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Originally Posted by kickin8
oh noooooooooooooooooo
the "new" one only last for 2 years?!
First one lasted 2 years, second one lasted 2 years.
Both in the middle of summer.
Jeff
Old 08-13-14, 12:25 AM
  #47
GiantsFan
GiantsFan's Avatar
I'm on my third windshield as well! (Including factory one)
Great work
Old 08-13-14, 12:28 AM
  #48
BoyOhBoy
BoyOhBoy's Avatar
Great work
Why'd you have to change it so many times?
Old 08-13-14, 12:58 AM
  #49
GiantsFan
GiantsFan's Avatar
Huge rock smashed into my OEM one and it developed a crack all the way across within hours ... and my second windshield cracked when a rock hit it close to the top edge. Both times on the freeway. This 3rd one is holding up well so far
Old 08-13-14, 09:44 AM
  #50
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Similar to me, though I don't actually remember the first one happening, went out and got into my car, saw the windshield cracked, got out to look and there was a big chip where the wipers are. Second time was on the highway and it hit almost right at the top of the glass.
Jeff
Old 07-17-16, 05:25 AM
  #51
nyis250
nyis250's Avatar
Jeff,
Other than the windshield(1), Upper Molding(4) and Dam(3) on the below picture. Do you remember how many of each clips and rivets are required to replace your windshield?
Also, there should only be 2 LEXUS OEM glass right? One with rain sensor and one without?
56101-53907-8N w/o rain senor
56101-53908-8N with rain senor
OEM Winshield
Many Thanks!
Old 07-17-16, 06:52 AM
  #52
HankMoody
HankMoody's Avatar
Old thread, but good info. Thanks for reviving
Old 07-17-16, 08:45 AM
  #53
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Originally Posted by nyis250
Jeff,
http://cimg6.ibsrv.net/gimg/www.club...252f3782690.pn
OEM Winshield
Many Thanks!
0-10 (probably 10) side moulding clips, 0 rivets, 0-2 (probably 2) side mouldings.
You shouldn't need any rivets, but the clips and mouldings are almost impossible to save. You will probably need to replace most if not all of them.
There are 4 types of windshields, heater or non, with or without rain sensor. Heated was only used in Canada on 2010+ models.
Jeff
Old 07-18-16, 05:18 AM
  #54
HankMoody
HankMoody's Avatar
Jeff
Hey Jeff,
When removing the left and right windshield trim (mine is showing it's age) how does it come off ? What tools did you use to remove it, while not damaging things, i.e the windshield or A pillar paint ?
Old 07-18-16, 08:39 AM
  #55
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
I'll be completely honest with you, if you are at all worried about damaging the glass or the paint, break the trim pieces. Anything else could easily result in scratched paint, etc., if you slip. If you are very careful you can pry up on the trim slightly where it touches the glass and get a pick/trim removal tool underneath. Each of the 5 clips that snap onto the rivets on the body have 2 slots that clips from the trim snap into, so there are 10 clips to release per side and they're pretty tough to get out. The first time I tried I managed to get 8 of them released and then the top 2 were actually just barely touching the glass adhesive (from the factory) and they would not release. I ended up having to break both sides to get them off because of that.
If you want to get them off the easy way without damaging anything, just pull on the trim straight upwards away from the glass. The clips are fragile and will break very easily.
Jeff
Old 07-18-16, 09:21 AM
  #56
strikeraj
strikeraj's Avatar
is it possible to retrofit a 2008 is350 with the heated windshield from 2010+?
Old 07-18-16, 10:14 AM
  #57
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The glass would fit, you'd need to wire it up yourself though, the connector to plug into the windshield and the one to plug into the switch wouldn't be there obviously.
It wouldn't be ridiculously hard to do though.
Jeff
Old 07-18-16, 10:35 AM
  #58
HankMoody
HankMoody's Avatar
Jeff
Thank you sir ! Just what I was looking for..
Old 07-18-16, 03:27 PM
  #59
iJDMTOY
Former Sponsor
iJDMTOY's Avatar
Impressive! Thanks for showing all the DIY people how to do this!
Old 07-22-16, 12:30 PM
  #60
strikeraj
strikeraj's Avatar
Jeff
Do you know how I can find out what parts I need to get and the wiring diagram?
Will techstream subscription have everything I need to tackle this job?
Quick Reply: Installing a new windshield myself
