Wiring Fog lights to come on with DRL's or......
Old 07-14-12, 09:25 PM
dci4life
dci4life's Avatar
Default Wiring Fog lights to come on with DRL's or......
So i recently saw a pic on CL of an IS250 with his Fog lights on with the DRL (daytime Running lights). I think it looked cool. Is there anyone that can do a DIY for how to do that? Or clue me in on what wires to merge or how to wire up this mod.
Also i have the Vaistech V-line LED lights, If i can't do the first option of wiring up fog lights with DRL How do I turn them off (maybe i could just pull out the bulb) so i could just have the V-lines on without the OEM DRL's on........ but isn't it just the Bright bulb so i wouldn't have it. Im totally clueless on this topic.
Old 07-14-12, 11:18 PM
Silec
Silec's Avatar
youre going to have to tap into the ignition wire that is in the driver side fuse box under the hood and run it into a relay that is independently power so that whenever the ignition is on the fogs will be on.
heres an example of the wiring you will need to do.
http://www.allfordmustangs.com/forum...m-foglites.jpg
you can also add a switch and run it into the cabin so that you can turn the fogs on and off whenever you have.
Old 07-14-12, 11:22 PM
Silec
Silec's Avatar
here is a oem foglight switch that is used in the FJ crusiers
http://www.ebay.com/itm/FJ-CRUISER-F...e99d8e&vxp=mtr
here's another method of doing it.
https://www.clublexus.com/forums/is-...ification.html
Old 07-15-12, 07:15 AM
dci4life
dci4life's Avatar
Is there a way to keep the OEM DRL's from coming on so I can just run my V-line lights?
Old 01-10-16, 04:38 PM
Philsogood
Philsogood's Avatar
Bump. Sorta like this
View this post on Instagram
I'd love to know how this is done.
Old 01-12-16, 04:13 PM
jay350
jay350's Avatar
Search the forum there's a diy showing how to turn on the fog light without turning on the headlight. It's not hard
hovik92
05-20-14 09:43 AM
VinnRock
IS - 1st Gen (2001-2005)
03-11-09 11:49 AM
jbmah
06-05-07 07:50 AM
Adam2562
03-20-06 11:42 AM
JTMav
02-27-06 12:14 PM
Quick Reply: Wiring Fog lights to come on with DRL's or......
